Question about HP OfficeJet 6110 All-In-One InkJet Printer
Stripes Printed documents look OK. Color photos print with pale colors and faint stripes width wise like looking through venetian blinds. I cleaned and aligned carts, then replaced with new #57 and 58. No improvement. Do I need to clean something?
  • johncongemi Sep 18, 2007
    Thanks for the quick response. I had already done the alignment, and the autoamted cleaning. Turns out the new cartridges were near the end of shelf life. I tried again with FRESH new ones, problem solved, expensive process. Have learned that HP carts arevery age sensitive. Thanks again.
  • HP Master
  • 691 Answers
You could try doing an alignment which i think is a maintenance option on this machine. You should find it in the driver options. You could also look at my previous posts about under head cleaning. Look here -> http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Posted on Sep 18, 2007
When i try to print a photo i get white stripes across the photo. I bought a new ink cartridge but it didn't help.
White stripes across a print-out usually indicate clogged printer heads: look at your user manual on the cleaning procedures.
You can try cleaning BOTH the Black and Color cartridges heads by gentling cleaning and wiping the heads with clean moist tissue paper/kitchen paper. Also clean and dry the contacts (eg. copper looking printed circuit).
For bad and very dirty print heads, I also use a warm shallow dish of water and wash the head only and then dry off with clean tissue paper.
After re-inserting the cartridge, I suggest that you do a cleaning cycle and alignment and do a test print to ensure that the printing is back to normal.
Hope it helps: let me know how you go.
Dec 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
Color prints out photos in stripes
if you are getting stripes in photos then there is a problem with cartrige, take a cotton swab and dip it in water and clean the cartridge head and then try, and if still the same problem exist replace the color cartrige.
Feb 14, 2010 | Office Equipment & Supplies
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Prints B&W in Horizontal Stripes
I received an answer elsewhere. Thank you.
Jan 26, 2010 | Canon Office Equipment & Supplies
Printing in strips with gaps
Not sure if you have vertical or horizontal stripes but here we go
Nov 13, 2009 | HP LaserJet 1100 Printer
Color printer printing out 2 parellel stripes on the paper
clean your printer with a soft brush.....then wipe rollers with a damn cloth...
Oct 06, 2009 | Konica Minolta magicolor 5430 DL Laser...
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
