Question about Sony DVP-NS575P DVD Player
Durabrand PVD709 my DVD player suddenly started automatically rewinding (backwards) itself. I put in the DVD and it loads, but the little hand comes up in the top left corner, it says play, then within 2 sends it rewinds. It will continuously do this. No other buttons work, remote either. Now here's the kicker....if you continuously hold down the search or setup button while it's playing, this seems to "over ride" the rewind and movie starts to play. The setup screen does not appear though. As soon as you let go, it rewinds again on it's own!! Help please! Thanks!!!
    President:
  • 3,130 Answers
You have a bad tact switch behind the front panel rewind button.
Posted on Sep 18, 2007
SOURCE:
Will not play
Hello Brandon
The fault is with its Laser Picku Unit itself. The sled motor, the motor that spins the disc inside the DVD player, should wok like this as you details here. Just see, when we put in a disc inside any disc player, it will sart spins, after it has been loaded properly into the mechanism. The the laser pickup unit will start scan the recording on the disc, reads it; recogonize its contents, then starts to play from the first track. This is an automatic process ot all disc players, and suring this reading process, the spin speed of the disc will vary, may stop, or rewind to a little and then spins again. This is a common process to all the playeres.
Here, with your DVD player, the laser pickup unit tries to read the tracks, but fails, the again it starts to readit, fails and finally show a 'No Disc' display, as it hasn't got any details about the recoding at the inserted disc.
There are three main causes for this fault. The first one is with a faulty strip wire. This wire is one, that connects the laser pickup unit with main board. You can see a flat ribbon type cable that connectes to laser pickup unit at the mechanism, to the main circuit board of the player. Replace this cable fist. This cable can be purchased from most of the electronic spare part shops at your town, and won't cost more.
The second chance is with dirty or dusty laser pickup unit lens. To cclean this lens, the easisest way is to put in a lens cleaning disc into the unit, play it for at least three times, by ejecting it out and get it into. This process will clean up any dirt or dust accululated on the lens, and will help you. The cleaning disc also can be bought from most of the electronic spare part selling shops at your town.
The third chance is with a faulty Laser Pickup Unit istsef. If so, there is no repair to this unit other than replacing it with same type and number. It is a skilled work, and you have to disassemeble and reassemble the deck mechanism. If you have experience to dothis, you can do it by yourself at home Ok
Please do rate this solution, if it found helpfull to you.
Dec 29, 2011 | Durabrand PDV-709
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a Durabrand dvd player pdv-709 It was working good but now whatever I put in it attempt to load and after a moment it says error no discr
first you put lens cleaner disc in dvd player, it's not clear the problem,than change lens cord and lens. thank you.
Oct 11, 2010 | Durabrand PDV-709
Doesn't recognaize when dvd is in
TAKE OFF COVER AND ,,BLOW IT OUT ,,USE AIR COMPRESSER IF YOU GOT,,SHOULD HELP ,,ALSO A DISC CLEANER
May 15, 2009 | Durabrand DVD-1002 DVD Player
DVD player wont play just says loading and than stops
there might be dust on the lens. try cleaning both the lens and dvd itself.
Mar 28, 2009 | Durabrand PDV-709
Dvd plays cd's but not dvd's - gives no disc message
I have a durabrand portable dvd player we've owned for about 1yr and had just started messing up. When you put the dvd in it says it's loading and shows the blue dvd screen it just wont come on but you can hear it trying, please help what could be wrong?
Aug 12, 2008 | Durabrand DUR7 Portable DVD Player
I have a durabrand vcr/dvd modelPDV5001 I would like to know if there is a code I can put in to play a DVD I bought in the USA as it comes up wrong region.
I paid £3-49 for imformation from you, but after saying my VCR/DVD was Durabrand
PDV5001 I got in the down load every thing else but the one I asked for that is not fair.
Bird36.
Jul 09, 2008 | Durabrand Televison & Video
Quick Start Guide for Durabrand DVD 1002
place one end of the scartlead into av 1 or av 2  on back of  tv,
other end of scart to dvd player .
plug dvd player  in,and turn on dvd player it should detect the dvd and turn to dvd channel automatic .
Oct 23, 2007 | Durabrand DVD-1002 DVD Player
Blue screen
there's a little button under the screen that turns the screen off when you shut the top look close and flip it till it comes on, they become stiff in some models and don't always pop up so with a little flip it should
Oct 06, 2007 | Durabrand DVD-1002 DVD Player
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Sony DVP-NS575P DVD Player Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
