Question about Mitsubishi VS-4543 45" TV
NO PICTURE
WHEN I TURN TV ON THERE IS NO PICTURE. I GET SOUND. THERE ARE THREE LINES THAT GO ACROSS SCREEN. ONE IS RED ONE ,IS BLUE ,AND THE OTHER ONE IS GREEN. BEFORE THIS STARTED HAPPENING THE TV WOULD GO OFF FOR A COUPLE OF MINUTES THEN IT WOULD TURN BACK ON. WHAT IS THE SOLUTION?
  • leife56 Aug 22, 2008
    One year ago I had a Tv repairman come out and replace a vertical chip which solved the problem on my 51 inch apex tv. Recently, I've had him out again and he has come to the conclusion that both of the convergence ic chips that he is calling amplifiers need to be replaced. Is this possible? How much do these chips cost? And, is there a code that you can enter into your apex tv remote to make certain adjustments? Thank You
    Genius:
  • 1,153 Answers
GO TO THE CONVERGENCE MENU (MENU 2 3 5 9) AND CHECK THE ADJUSTMENT SETTINGS FOR CONVERGENCE. IF ALL ITEMS ARE SET AT "127". THE EEPROM SETTINGS ARE AT DEFAULT. CLEAR THE CONVERGENCE MENU AND ACCESS THE OPTION MENU (MENU 1 3 7 0) USE THE ADJUST BUTTON TO SELECT E2RESET AND PRESS QV. THIS SHOULD INSURE THE EEPROM IS CLEAR. AT THIS TIME ALL ADJUSTMENTS, CONVERGENCE GEOMETRY AND CONVERGENCE SHOULD BE DONE. IF MISSING, WEAK OR DISTORTED, CHECK PULSE AT SOURCE PIN 7 OF IC401 (PUMP UP OUTPUT) ON THE SIGNAL PCB, IF THE PULSE IS NOT CORRECT AT PIN 7 CHECK C402 100 UFD 50V AND IC401 PART # 270P064020. 3. CHECK FOR -5 VDC TO THE CONVERGENCE PCB AT "GM" CONNECTOR PIN 10, IF LOW, MISSING OR NOISY, CHECK C936 (1000 UFD 16 V) AND C935 (100 UFD 16 V) IN THE -8 VOLT SUPPLY CIRCUIT ON THE MAIN PCB. 4. CHECK C924 (1000 UFD 36V 105 C) AND C925 (100 UFD 50 V) IN THE -24 VOLT SUPPLY CIRCUIT ON THE MAIN PCB.
Posted on Sep 18, 2007
  • Lashawn Robinson Sep 18, 2007
    My Bad do this first, I read too fast and have many more to go. CHECK PIN 4 OF IC401 FOR 3 VDC IF MISSING CHECK IC202 (5V REG) PART # 266P932010, ON THE SIGNAL PCB. 2. MAY BE INTERMITTENT. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. Then if still a problem do the other I wrote before. Sorry for mix up.
    Champion:
  • 317 Answers
Your tv most likely has a bad vertical chip or cold solder on this chip. Another thing is that the connections on the vertical yoke connectors are broken and need to be resoldered....John
SOURCE:
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Black screen with 3 colored lines going across
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
I have a Sony Big Screen Projection TV
unless you work on t.v.s this is nothing you can service.check your warranty &/or call a qualified service tech.hope this helps
Nov 15, 2008 | Sony KP-57WS500 57" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
256 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
