Question about Kenmore 24032\24036 Top Load Washer
Will not fill
The washer will spin and drain fine. Bu tonce the knob is pulled to fill (start wash cycle),it'll spit out a little water then trip out. Something in the selector dial assy? Plus, is there an easy way to get to the dial panel wires without taking the whole back of the washer off?
  • 240 Answers
To get into the console, first remove (unsnap) the front console end caps (just the front coverings).  After you remove these, you will see 2 screws on either side at the lower edges.  Remove these two screws, then pull the console slightly towards you to unclip the console.  Then rotate the console up and over the back.  It has hinges, so should stay up while working on it.  Water problem sounds like you have an issue possibly with pressure or mixing valve.  Remove the water inlet lines, and be sure the screens are not clogged.  Does the water switch change temp and if it does does the pressure change?  Could be a faulty mixing valve (the part that the hoses hook to).  It could very well be that switch as well.  The water valve is probably the least expensive of the parts, as those switches get a little expensive.  Let me know how it turns out.   Jim
Posted on Oct 18, 2007
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    Washer will not complete cycle
    washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
    Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
