Question about Mitsubishi WS-65909 65" Rear Projection Television
I am buying a Mitsubishi WS-65909 from aprivate seller and I read
That there are 2 pieces for delivery. I am picking it up Monday. My question is how do I disassemble it into 2 pieces so I can pick it up?
Yes that tv does, and its just screws on the side, take them out and lift the top off, best if u have 2 people. top part is pretty light as it is just the screen and a mirror, bottom has the rest and is heavier
Posted on Jul 06, 2009
  • 126 Answers
You have been mislead. I just checked the service manual and that model does not seperate in two like some Mitsubishi's do.
Posted on Jun 11, 2009
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi ws-65807 error code 2-2
2,2 error is short protection in this model.
WHAT IT MEANS IS ONE OF THE TWO FUSES THAT PROTECT THE CONVERGENCE CIRCUIT IS BLOWN; This model uses 2 of the STK-392-570 CONVERGENCE chips---
I have photos of the fuses etc--fuses and chips are located on the middle circuit board which would have to be removed to repair. I also have step by step start to finish instructions for this repair in this model.
If the parts needed are purchased on EBAY (I can tell you the name of a seller there) total parts cost is under 25 dollars and repair takes about one hour.
Many shops will not do this repair in the home and most will get 250 plus for it not counting pickup and delivery.
How handy are you? I can post the instructions and photos here if you respond to this answer by "add a comment".
SD TECH
Jul 28, 2010 | Mitsubishi WS-65909 65" Rear Projection...
I have a mitsubishi ws-65909 - flashing 2,2. Can
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Nov 13, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My Mitsub. ws-65909 green power light turns on for about 3-4 seconds, then shuts off. Ideas ??
Replace Both of your STK ICs they are big black ICs will have # on them STK392-570? Call Mats for Parts 1-800-628-1118
Sep 24, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65909
I can point you in the direction of locating some manauls
http://www.eserviceinfo.com/most_popular/list_5800.html
www.servicemanuals.net
Jan 04, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
