Question about Kitchen Ranges
Change light bulbs in rangehood
I have a Baumatic BT7.3GT Rangehood and need to change the light bulbs. How do I get them out to replace them. I have tried screwing the surrounds clockwise (and anti-clockwise) but they only move a small amount. I can see some slots but not sure if I should lever the existing light bulb out. Any assistance would be welcomed. Thanks Andrew in London
I found the instruction manual on the Baumatic website.
Thanks anyway
Posted on Apr 19, 2009
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
How do i change a light bulb in rangehood
There should be two screws underneath to remove the panel that the light is in. It may have one on each side. Remove the screws and drop the panel. If this does not cover it, reply with the model number of the hood.
Mar 10, 2015 | Washing Machines
Why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Jun 27, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I want to clean the filters on my Baumatic Rangehood. I have removed them but can't find instructions about what to use eg very hot water? Warm? Detergent? etc
The metal filters can be cleaned with ANY good degreaser. The carbon filters need to be replaced. Parts are available from the manufacturer or an appliance repair shop that handles your brand.
May 02, 2010 | Baumatic Upright Freezer BV12A
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Kitchen Ranges Logo
566 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
