Question about Dell 1700 Laser Printer
Does not pick up paper from the tray
Hi I have a dell 1700 printer and it has stopped picking up paper from the tray
    Genius:
  • 1,605 Answers
How much paper gone throught the printer since it is new?
usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
Posted on May 13, 2009
Is not recognizing that it has paper,light states needs paper,it is not picking up paper from the tray
There is usually a photo sensor in printers or sometimes a mechanical switch in the paper bay which notifies the printer logic that there is no paper, it is probably this system which has failed.
If you're really lucky sometimes paper dust covers the light sensor and a quick blast of compressed air resolved it, other than that its a repair job.
Mar 13, 2015 | Dell 1700 Laser Printer
Tip
Dell 1700 1710 series printer. Paper not picking up trick....
Here's a quick tip. If your Dell 17XX series (not confirmed for newer than 1710dn printers) is no longer picking up paper from the tray, it MAY be from worn out rollers. Try this tip to get it going while you wait for a replacement roller to get to you:
1 - remove the paper tray
2 - remove toner
3 - flip printer upside down (exposing the rollers)
4 - remove the rubber on the roller
5 - invert it. (turn it inside out)
6 - replace rubber back onto roller (still inverted)
7 - test print.
If this doesn't work then the problem is likely a paper setting (set to legal or something) Good luck.
on Aug 27, 2010 | Office Equipment & Supplies
Dell 1700 printer doesn't pick up paper - have reversed the rubber rollers and still isn't picking up
It sounds as though the rollers are needing to be totally replaced. There are other rollers as well and pickup pads that need replacing after awhile. I suggest taking it to a Lexmark dealer as the Dell and Lexmark printers usually take similar parts. They may even sell you the parts to replace yourself if you know what you are doing.
May 27, 2010 | Dell 1700 Laser Printer
Dell 1700 printer paper not feeding. It's getting halfway and stops.
Take off the pick up rollers. Turn them inside out and put them back on.
Dec 18, 2009 | Dell 1700 Laser Printer
Have 1700 that picks up paper then stops after pick up
We use these printers in the computer labs at the school district I work for. The easy inexpensive fix is to turn the rubber bands on the rollers inside out.
Sep 21, 2009 | Dell 1700n Laser Printer
2 Dell 1700 printers both have started jamming pages
Easy fix. Replace the pick up rollers. There cheap and easy to replace. It make perfect sense, bought at the same time and use the same amount then the pick up rollers are going to wear out causing paperjams at the same time.
Jul 15, 2009 | Dell 1700 Laser Printer
Feeder dosen't pick paper up from tray
Steps you should follow;
1. Clean roller with Isopropyl alcohol not water /soap.
2. goto www.dell.com or www.marketpoint.com to order the needed parts.
Good Luck,
Rich Lilja
Apr 08, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell 1700 printer will not print
Hi albrecht,
i think u might have used ur printer without paper often . unplug the printer from system and switch it off.Replug it again on the system ant switch it on and see. Even then if it is not printing uninstall the drivers for printers and reinstall again and print.
Mar 04, 2009 | Dell 1700 Laser Printer
Dell 1700 Laser Printer Logo
250 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
