Question about Bose Lifestyle 48 System
1.dvd stops playing and says cannot read disc 2.dvd also states cannot read disc in insertion to problem solve this i place it in several times then it loads up.... 3.Also storing cds only stores 60-70% then stops loading
Please check this video... It shows how to clean the lens on Bose Lifestyle systems.. http://www.youtube.com/watch?v=BrvETLjKloY
Posted on Jun 03, 2009
I've inserted several dvd's and cd's which are not being read with the display stating nodisc.The problem first started with a dvd stopping after showing about 75% of content, and since stopped working...
There can be 2 reasons for this 1. might be a collection of moisture or 2.dust.
For both put the dvd in a warmer room for about 2 hours for(unplugged) and let the moisture evaporate.
Try it again.
If dust is there blow throught the area where the dvd enters.
Also remember you can only play certain discs, and the area code should be correct.
Oct 19, 2009 | Samsung DVD-R155
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
DVD WONT PLAY...DISPLAY SAYS READING
try a cleaning disc or clean the laser .could be just a bit of dust..good luck .farr64
Apr 29, 2009 | Bose 3·2·1 II System
DVD player won't work for Panasonic SC-HT680
la tarjeta de elcctricidad se me quemo y no encuentro respuesto
Oct 11, 2008 | Panasonic SC-HT680 System
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
RE: Problem with SAMSUNG DVD-R135
If I understand correctly It would play DVD-R just fine & then it was no longer able to read them. If this is the case, are you using the same brand of DVD-R discs? Some read better than others Try using Imation they seem to read in alomost anything. If you still have problems I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. If it worked correctly in the first place I would assume a firmware update would not fix the problem. It is harder for the drive to read a burned disc than a pressed disc so that is why I recomend cleaning the lens. It has always worked for me.
If it still will not work then I would say that the laser pickup is failling, If thats the case in time it will no longer read retail DVD's
Feb 17, 2008 | Samsung DVD-R135
Insert DVD and screen says "No Play"
try to clean first with lens cleaner
Jan 04, 2008 | Sony DAV-BC150 System
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Bose Lifestyle 48 System Logo
756 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
