Question about Garden
Fluid in reservoir not coming through when jet washing
When jet washing with my Mac Allister 360PWA the fluid in the reservoir is not coming through. I have mislaid the instruction book.
SOURCE: Suddenly leaking power steering fluid, reservoir empty
The best bet is its trans oil. The gearbox has crushable washers/gaskets, the bolts may just need to be tightened slightly to crush the gasket and seal.
Posted on Jul 12, 2008
  • 350 Answers
SOURCE: My washer fluid is not coming out though it is filled with washer fluid
hi first of all can you hear the motor working if not check the motor if you can you have a blockage either a traped pipe if you have been filling with washing liqiud or simular the jets can get blocked or a pipe has a break or come off yates210456
Posted on Oct 09, 2008
SOURCE: instruction book
need the manual for the belling idw604 dishwasher
Posted on Nov 26, 2008
hotrodtod38
  • 141 Answers
SOURCE: Brake fluid reservoir on a 2005 Chrysler Pacifica
WHEN YOU OPEN YOUR HOOD LOOK DOWN THE DRIVER SIDE FENDER THEN LOOK LEFT ABOUT 10 INCHS AND YOU SOULD FIND IT IT WILL BE WHITE IN THE ENGINE COMPARTMANT AREA
Posted on Feb 14, 2009
SOURCE: have oil in my radiator fluid reservoir tank (1996 v6 3.8)
Twice in two years now my Saab 9-5 has had a pin-hole in the oil cooler, which has caused oil to flow into the reservoir. A way to tell is if coolant/oil is coming out of the reservoir cap. The reservoir cap is rated for the pressure of the coolant system, which is significantly lower than the oil pressure. When there is a hole in the oil cooler, oil will be forced out at relatively high pressures, causing the reservoir to fill and then over pressurize and spill out of the cap.
Posted on May 19, 2009
How do I get a user manual for a mac allister power washer mhpc 130-p?
www.miningequipmentcost.com/.../mac-allister-petrol-pressure-washer-p
www.mobile-impactor.com/.../mac-allister-petrol-pressure-washer-pdf-m.
Jun 11, 2014 | Televison & Video
Audi Q5 low wiper fluid light on but reservoir full
the low washer fluid sensor might be shot. try replacing it. hope this helps.
Mar 05, 2014 | 2011 Audi Q5 2.0
Spares for macallister MAC360PWA
looking for a pressure hose for mac allister 360pwa
Apr 03, 2013 | Garden
Window washing fluid pump isn't working. Hums and runs, but no fluid comes out. Any ideas?
1. the washer fluid jets are plugged possibly and will not allow fluid to discharge. Take a small wire or needle and stick into the jet end where the fluid comes out and it should spray after that if that is the issue.
2. the lines coming from the washer pump could be broken or cut open. Remove the line at the back of the spray jet either at the hood or at the wiper arm, then attempt to spray the wiper fluid. If it does not spray then there is an open/broken line coming from the washer pump or the pump may have a problem. If fluid is coming out of the line, the jet again is plugged up. Also check to see that fluid is going into the washer pump (locating the pump and getting to it is sometimes not so easy depending on where the mfg put the pump).
Jan 18, 2013 | 1986 Buick Century
Wiper fluid comes out only on driver side when trying to clean window. Is there some sort of manifold or solenoid valves that dispense the fluid to each side. Also when trying to clean rear window no...
Look at the fluid canister, You will see a hose that leads to the hood and splits to the right and left. The hose that leads to the pass. side could be clogged up or the fluid jet that fluid comes from could be clogged up. Disconnect the hose from the pass side jet, and see if fluid comes out when turning on. If so, then the jet is the problem. These can be bought from a parts store, but will not be OEM. the front and back are controlled with one pump, which I don't think is the problem. The rear may be the same problem, try doing the same as you do for the front. Sometimes the car wash soap you use or wax can build up and block the jet hole up.
Jun 13, 2010 | 2003 GMC Yukon XL
Wiper fluid doesnt come out
can you hear if the pump is running ?,if so check for a blocked one way valve that stops the fluid returning back to the reservoir somewhere in the lines ,also clean the jets with a pin...
Apr 10, 2010 | 1989 Ford Ranger
Trying to wash the windows and no washer fluid comes out
can you hear a zzzzzzzzzzzzzzz sound from under the bonnet? if not its possible your washer jet pump has broken they are located on or around your washer bottle and cost around £10 or $15/$25 and should be easy to fit yourself
Tom
Jan 16, 2010 | 2003 Chevrolet TrailBlazer
Just bought a 1987 Iroc Z. Need to know why my
look at waser bottle and there is a pump . replace the pump very easy to do
Nov 12, 2009 | 1987 Chevrolet Camaro
No wiper fluid is spraying out when I activate the wiper wash
WHEN YOU TURN ON WASHERS CAN U HEAR THE PUMP WORKING IF YOU CAN IT WILL BE
BLOCKED WASHER JETS OR LINE OR WASHER PUMP IS FAULTY.
Dec 17, 2008 | 2003 Honda Civic
Oct 09, 2008 | 1999 Oldsmobile 88
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
