Dc jack of a toshiba satellite A55-S603
Have to play with the plug in order to get it to work
  • Gator_RonS Jan 03, 2009
    The male jack on the unit was causing the power to be intermittent. It totally failed. Need repair manual to get into unit to fix jack. Removing the four screws does;nt release the housing halves.
    Genius:
  • 1,153 Answers
Look inside on board where jack goes in and look for loose solder connections and resolder.
Posted on Sep 18, 2007
SOURCE:
I need to replace the dc jack in my toshiba A55-S1063 (satellite) but i'm not sure of the pin size before i place my order
Your laptop uses a jack already soldered to a cable with socket. Ebay has them for sale for around 33 bucks. All you have to do is strip the laptop down to the board, unplug the socket lift the jack out and plug the new cable in. Below is the item number on ebay, just put this number in the search box and it will show you the part and you can contact the store directly. Good luck.
item number 110363157528
Nov 15, 2009 | Toshiba Satellite A55-S1063 Notebook
Where to download toshiba satellite a55-s3061
for all toshiba drivers which u cnt get on the official site u go to http://driverscollection.com/
Aug 11, 2009 | Toshiba Satellite A55-S3061 Notebook
Toshiba satellite a55 s1063, driver wireless
They are all right here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132282&rpn=PSA50U&modelFilter=&selCategory=3&selFamily=1073768663&selModel=1132282|PSA50U
Click on the Downloads tab and then choose windows xp as your operating system and you can download any of the drivers that you need from that point.
Mar 14, 2009 | Toshiba Satellite A55-S1063 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Battery will not charge
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Toshiba satelitte notebook
The first thing to do is eliminate the external power supply, the DC jack and the socket on the laptop that it plugs into. My experience has been that damaged jacks are far more common than damaged sockets. Usually what happens is that someone trips over the power cord and puts strain on the cable where it attaches to the jack. A quick test is to plug the DC jack into the laptop and while holding the jack still wiggle the cable where it attaches to the jack. If that doesnt do it try holding the jack and wiggling it in the laptop socket. One or the other should cause a break in the power and youll know what to get fixed or replace. If those are the usual suspects, however, if they all test out OK then let us know what the results were and we?ll pickup from there. Any additional information will be helpful such as LEDs, how long it takes to shut down and any issues that may have led up to this.
Jul 30, 2007 | Toshiba Satellite A55-S1066 Notebook
82 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
