Question about Mtd Garden
With cutter engaged no cutting taking place
MTD Yardman Model No. AN5150 ride on mower. When engine is running and the gear engaged blades will not turn. New belt fitted recently which seems ok and worked satisfactorily for 2 cuts but problem arose half way through the third cut. Could the problem be a clutch and if so which part no and price for me to rectify.
  • 16 Answers
SOURCE: my mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
Posted on May 30, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 9 Answers
SOURCE: I have a MTD 0675
check to see if the belt is in the correct routing, most belt tensioners are able to be fitted with a factory belt in a couple of different routing methods, however only one is right to keep the belt from slipping, look for a belt routing diagram on the mower deck they are the best source fot this information.
Posted on Jan 12, 2011
jcameo7270
  • 675 Answers
SOURCE: i fitted a new belt
Make sure the routing of the belt is correct....then check to see that you have obtained the correct belt
Posted on Jan 15, 2011
Hi, i have a yardman ride on mower which, while working, has stopped cutting. i looked underneath and found a rock wedged in between the blades and the side.
If the blade turns freely while engaged (and engine off) then some part of the drive-line is disconnected or broken.
May 23, 2017 | The Health & Beauty
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mtd pinto mower engine cuts out when cutters engage - why?
May 23, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
71 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
