Question about Beach Tek BeachTek DXA-FX, FX1 XLR Adapter for Sony HDR-FX1 HDV Camcorder
Problems recording from soundesk
I tried to record from a soundesk last nite. i hooked up both channels but when i listened thru my headphones it was very distorted. I had the limiters on and turned the manual volume to about 3. i have got another shoot tonight so i would appreciate some help please.
Thanks
Steve
The signal from a sounddesk is a line signal. On the bottom of your Bechtek are 3 dip switches. You have to set switch 1 and 3 to line level. That should work.
Posted on Jul 05, 2009
Our tv sound is muffled on all channels and even the shows recorded much earlier, which leads me to think it is the sound from the tv, any suggestions
Try listening with headphones. If that resolves the problem, then your TV speaker amplifier has failed, or your spakers have.
Sep 07, 2017 | Televison & Video
I have a audio interface : alesis io2express And headphone :Sol replubic I start a vocal recording and after that I listen to it but I found out the it give me a buzzing and like robotic sound I tried turn...
Sounds like you may be recording electrical interference from another electrical source as well while trying to record your vocals. Try unplugging other electrical devices that are in the area of your recording equipment, then try recording again. If that doesn't work, move your recording equipment to another location and try to record again.
May 06, 2014 | Computers & Internet
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
I. Have a profx12. I am running just into laptop.i want to use my jvc receiver to playback recording instead of listening through headphones. Is this possible.
it should be if you hook something up to an input channel like w the band i was in i had to hook my turntables up to a microphone jack on an open channel . so yeah if u plug lets say a cd player plug the output of that into the input of the mackie and make sure you have your speakers in the output of mackie all set up and it should work no problem. We have the same mackie
May 28, 2011 | Mackie ProFX12 Professional Compact Mixer
I have an Akai MG1214 12-Channel mixer/recorder. I am getting a loud hum that seems to be triggered by applying a patch cord to any of the master outputs and connecting the other end to the sound card of...
Did you ever get an answer, i get similar problem, everything seems to be fine when i listen to the MG'S thru headphones but gets a hum as soon as i try to get out thru another piece of gear...
let me know.
Best!
Jun 17, 2010 | Audio Players & Recorders
Speakers only work with headphone
It is only a slight software problem.You can solve it either by updating your phone's firmware or re-installing phone's software.
Apr 09, 2009 | Nokia N81 Smartphone
Plugging in keyboard
MIDI only carries digital information, not audio. Midi is used to communicate patch settings and note value information. If you want the recording to know the note value, then you should use midi. This is useful if you want to do things like adding rythm tracks, etc.
If your keyboard has audio/line out (as opposed to headphone out), use that, as it is matched much better in impedance. If it doesn't have audio/line out, then you can use the headphone jack, but you will have to turn the attenuation way down because the headphone jack impedance is much higher. This will tend to distort on the recording if you are not careful.
The first thing to know about digital recording is that distortion is much more of a problem. I won't get into the theory of this, just know that impedance mismatching is more of a problem with digital.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Cant record vocals while listening to beat without the beat being recorded twice
i have the same probelm as da 1st guy,, when i record my vocals some how da beat sneaks into da mic too and fuccs it up.. seriously its ****
Jun 23, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Tascam mf p-01 portastudio
hi sounds like a worng channel or no output from something check the tape output's for anything if there is sound but bad or low then the tape is the problem if it's good then check that the cable connection is good (connect it to a reciver) then if all is good till the unit: check that you are listening to the right channel check that your output device is good (headphones,speakers) (connect it to a reciver) good luck
Mar 30, 2006 | Lexicon Omega Desktop Computer Recording...
Beach Tek BeachTek DXA-FX, FX1 XLR Adapter for Sony HDR-FX1 HDV Camcorder Logo
100 people viewed this question
Top Beach Tek Video Cameras Experts
Are you a Beach Tek Video Camera Expert? Answer questions, earn points and help others
