Question about Denon AVR-2802
Feedback noise? My AVR 2802 makes feedback noise when I put it on Dolby Pro Logic AND Stereo. Can anyone help me?
  • 682 Answers
Turntable and speakers are too close together----separate as much as possible.
-----floor is unstable and vibrate easily-------use cushion to absorb speaker vibration transmitted by floor.
Posted on Aug 04, 2008
SOURCE:
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
Denon Avr-3200 Dolby Digital not working
What I suggest is that you reset the receiver as you mentioned. If you look in your owner's, there will be a procedure that says, "Return to factory default, or Reset" I believe you have it set wrong, or are not providing it with Dolby Digial signal. Dolby Digital, is not processed by the DSP board(Digital Sound Processor), which handles the THX, Neo, and every other format. Dolby Digital, is one of the earliest form of Home Theater. It has to be processed through the 2 RCA jacks(left and right). It is really not used anymore, in light of Dolby Pro Logic, THX and others.
Dec 14, 2012 | Denon AVR-3200 Receiver
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Hi, I have a denon 2802 av receiver. My Dolby decoder seems broken, the doby-display-indiactor is blinking as soon as a dolby signal is receiced. resettting doesn't help. DTS is still working. Anaybody...
The processor that creates the surround is all on 1 chip so sounds like a software issue.
Call Denon to see if they have a firmware update for your unit this usually is free and may fix the problem
Feb 13, 2010 | Denon AVR-2802
I cant make the coaxial cable work with surround sound
Coaxial cable does not support 5.1 dolby surround sound. You could try setting the unit to Stereo Output instead. Also you could use RCA cables instead.
Jan 11, 2010 | Denon AVR-2802
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Not getting dolby digital or dts
Not available on this unit...accordianman
Feb 06, 2008 | Chaintech AV-710 7.1 Channel PCI Sound...
Denon AVR-2802 Logo
99 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
