Question about NEC PlasmaSync PX-42VM2A Television
NEC PLASMA MONITOR MODEL PX-42VM2G TURNS ON FOR ABOUT 2 SECONDS LIGHT GOES GREEN , THEN SOUNDS LIKE A RELAY CLICKS IT OFF THEN IT AUTOMATICALLY GOES INTO STANDBY,
  • 4234 Answers
SOURCE: NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Posted on May 13, 2008
SOURCE: NEC Plasma Sync 42MP3 Problem
Hi, This model has some design flaws and yes NEC admitted to them a year ago. The problem with your monitor (hopefully) is a bad power supply. Have a Tech with a voltage tool check the boards as well as the connections Reason, this monitor generates a lot of heat ( no cooling fans) primarily at the power supply and sits there. So the wires tend to go weak by the heat build up. What the problem is the power is not going to the correct board in the right voltage. hope this helps out!!!
Posted on Jan 16, 2008
SOURCE: nec px-42vp4a that turns off
Hello. I have the same issue with my px-42vp4a. Did you figure out the problem. Email me with you did. paulh77p@excite.com. Thank you. Paul
Posted on Mar 22, 2008
SOURCE: nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Posted on Jun 05, 2008
pabloloco
  • 2335 Answers
SOURCE: NEC PX-42VM3A 42" Power problem
I have read that this has been fixed with little more than a hard reset. This means just unplug your set for 10 minutes or so and let all the power seep out of the boards and capacitors, then plug it back it.
If that didn't fix it, your unit needs servicing. If you are handy here are some troubleshooting steps:
Check the fuse at Y-Sustainer pcb.
If blown do not replace. Look instead at scan converter boards. They are connected between y-sus & plugs from display (left side with face down, back open). Look for signs of 'burning' at upper and lower long boards. If any imperfections are found, replace all three boards: Y-sus, up & low scan.
If fuse was okay, check power supply for bloated capacitors (big board in middle of set).
I hope that helps.
Posted on Apr 19, 2010
NEC PX-42VP4DA
te power pack inside the tv has gone bad and needs replacement, contact manufacturer for parts.
Nov 25, 2007 | NEC 42VP4 42 in. EDTV-Ready Plasma...
NEC plasma PX-50XM5A with ghosted images
tienes un problema en el plasma de imgenes fentasmas lo que te sugiero que le hagas un buen mantenimiento
Aug 24, 2009 | NEC PlasmaSync PX-50XM5A 50 in. Television
Power issue NEC PX-42VM5A
Most likely a transistor - NEC used FSM series for a while which are now discontinued. Let me know if you need info on how to find/tell which parts are bad.
Jun 22, 2009 | Emerson LC320EM8 32 in. LCD TV
Problem with my NEC PX-42VP4PA
it goes on for a while and then shuts off after then the colour show not good i need help for this problem
Sep 12, 2008 | NEC PX-42VP4PA 42 in. EDTV-Ready Plasma...
Nec 42
who has manual for a nec 42 plasma monitor px-42vm2a date it was made is 12-07-01 it is a flat screen thank you email carl5545@bright.net
Apr 04, 2008 | NEC PlasmaSync PX-42VP2A 42 in. Television
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Power lite blinks red and will not turn on
Sounds to me like you're experiencing an issue with the power supply in the unit.
Nov 21, 2007 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Nec 42'' plasma
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Help
Same problem here. PX-42VM2A (NEC PlasmaSync 42MP2) Turns on (status light green) then goes to standby mode (status light red) after what sounds like some electrical relays clicking over. Opened it up and no glaringly obvious problem, but i'm no components technician so... Any ideas? Anyone want to buy it for parts or need a specific part? email me: 318noire<at>gmail<dot>com
Oct 13, 2007 | NEC PlasmaSync PX-42VM2A Television
NEC PlasmaSync PX-42VM2A Television Logo
411 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
