Question about Audiovox PPC 6700
Speaker microphone malfunction
I can no longer use my phone without a headpiece. Apparently the speaker and the microphone are malfunctioning. However, the notification sounds are still active. I can hear the phone ring, but I am unable to answer it without the headpiece. Also the phone will not let me enter voice activated numbers without the headpiece one. Any ideas???
  • 1 more comment
  • ssmall Sep 21, 2007
    I did a hard reset twice and it finally worked. However I find whenever I use the phone as a MP3 player at work hooked to speakers, the problem recurs.
  • lefthandofd Mar 09, 2008
    Same problem with my Sprint PPC 6700. Only change in usage was that I recently started using an extended battery. Seems like a mechanical problem with the headphone jack -- per the suggestions at http://pdaphonehome.com/forums/ppc-6700-..., I jiggled the headphone plug in the jack and eventually got the speakers to turn on.
  • ssmall Mar 29, 2008
    I actually found a dumb solution for my sound problem. When I use the phone for a MP3 player at work hooked to a stereo system, I just unplug the cord from the stereo while it is still playing so I can hear the sound coming from the PPC before I turn it off, the phone works just fine. I haven't had the problem now for over 6 months. I don't understand why, but it works for me.
I had same problem with my PPC so I tried hard reset didn't help, PCS support did hard reset and nothing, same problem so what I did is insert that headset plug in and out couple of times that fix the problem but any time I use my wired headset problem comes back.
I realized that the problem was in the 2.5 jack it self, I took it to Sprint store, left it for a hour when I am back the tech guy said that they replace my phone with new one, oh well this is third phone in less then 14 mos.
But anyway now it works just fine so I try to use Bluetooth headpiece much is possible. Waiting for my 2 year contract to end so I can get PPC-6800 or something better, had too many problems with this phone. I like the phone but it was freezing up on me every day and tech support didn't do s!#@!#t for me to fix it until this problem comes up, I'm kind of glad it did :-) in the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/toly_4d7df273bdf34d91
Posted on Mar 29, 2008
  • Toly Mar 29, 2008
SOURCE:
I have a 2009 GMC Yukon and rear speakers aren't playing
Does the system have an amplifier ?
Circuit/System Verification
Radio ON, Rear Seat Audio (RSA) OFF (if equipped), adjust the fade and balance controls on the radio to test all four channels individually. Each of the four channels should produce clear and even sound.
Without Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, replace the radio.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - without Amplifier.
With Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, refer to Amplifier Circuit Malfunction.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - with Amplifier.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the appropriate speaker.
  2. Radio ON, test for 5.0-7.5 volts between the signal circuit terminal A and ground.
  3. ?‡'
    If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
    If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
  4. Test for 5.0-7.5 volts between the signal circuit terminal B and ground.
  5. ?‡'
  6. If all circuits test normal, replace the speaker.
Apr 17, 2016 | GMC Cars & Trucks
When pressing the on/off button it is staying red and displayed on screen is F61 and thats all it will do
"F61" protect in other brand is an error code for short/overload on the following.
1. Inputs - speakers, microphone, Audio inputs from cable box, TV, etc.
2. Faulty internal Fan - Once the internal fan gone to malfunction, the unit will automatically turned to this error code to avoid further damaged most especially to the expensive parts like the sound output IC.
3. Power supply - if one of the power supply is not normal, same symptoms will be encountered.
4. Sound output IC - once this IC gone to malfunction, it will trigger the symptoms to avoid further damaged to power supply and speakers.
DIY steps to determine if the fault came from the board inside the unit is by disconnecting all of the inputs, speaker, microphone from the unit and turned it on without them. If the symptoms still persist, #2 - #4 parts needs to check to isolate the problem.
mjsazon
Oct 04, 2011 | Technics SCEH790 CD Shelf System
Mouth piece malfunction. how it can solve the problem.
The microphone is rarely malfunction on this phone if there is misuse of phone. You may have software problem and need to update / upgrade.
Just go to menu>> settings>> phone >> phone update , then go to nokia 5310 software update.
And check again your microphone.
Check also the sound volume in your phone. Don't set it to minimum.
Regards, Jay
Feb 19, 2011 | Nokia 5310 Cellular Phone
Battery
A noticeable malfunction of cordless phone due to batteries discussable
1. The cordless phone allows to acquire calls away from the receiver area
2. The cordles phone requires frequent battery charging becaus not designed for extensive sessions away from recharge docking station.
3. The further away the phone is from docking requires more battery
Problems with batteries discussable
1. a malfunctioning battery continuous to beep
2. A malfunctioning phone batteries requries replacement completely, cannot be recharged any more, remove, discard and acquire a new battery to replace soon as malfunctioning beeps are heard lasting several attempst to recherge without seizing beep.
Dec 02, 2010 | Siemens Gigaset A140 Cordless Phone
G1: I can talk to people on my phone but I can't hear them on headpiece. Only speaker works. How do I repair speaker in headpiece?
CALL T-MOBILE AND THEY WILL BE HAPPY TO GET YOU OVER TO THE RIGHT DEPT AND THEY WILL TROUBLESHOOT YOUR PHONE.....
Dec 01, 2009 | HTC G1
No one can hear me
Hello kpbmw
Based on the information provided it sound like the microphone has malfunctioned and these microphones can be replaced.
If the phone is less than a year old, it was purchased by you from the provider and it is in the exact condition is was when purchased you should attempt a warranty claim through your cell phone provider.
Can you recall an incident that occurred to cause the device to begin to malfunction?. ie Dropped, exposed to liquid? If so, you can visit this recommended repair center for an out of pocket solution.
Cell Phone Technicians
Possible temporary solution:
Use a wired / bluetooth headset or speaker phone option.
ERIC the PHONE GUY
Dec 15, 2008 | LG VENUS Cellular Phone
Person I am calling cannot hear me
Based on the information provided it sound like the microphone has malfunctioned and these microphones can be replaced. Can you recall an incident that may have occurred to cause this issue. ie Dropped, exposed to liquid?
Where to have repairs done: www.CellularTechnicians.com
Dec 14, 2008 | LG C1500 Cellular Phone
Person I call can't hear me
Hello alvarado,
Based on the information provided it sound like the microphone has malfunctioned and these microphones can be replaced. BUT FIRST CHECK TO MAKE SURE DEBRIS IS NOT CLOGGING THE MICROPHONE HOLE. LOOK OVER THE PHONE TO FIND A SMALL HOLE WHICH MAY POSSIBLY BE FILLED WITH SOMETHING. ( hope this is all but...)
If the phoneis less than a year old, it was purchased by you from the provider andit is in the exact condition is was when purchased you should attempt awarranty claim through your cell phone provider.
Canyou recall an incident that occurred to cause the device to begin tomalfunction?. ie Dropped, exposed to liquid? If so, you can visit thisrecommended repair center for an out of pocket solution.
Use a wired / bluetooth headset or speaker phone option until in a position to find a permanent solution.
ERIC the PHONE GUY
Nov 21, 2008 | LG VENUS Cellular Phone
Broken mic people cant hear me but i can hear them
Same here...mic malfunction i guess :( any thoughts?
Jan 13, 2008 | Nokia 1600 Cellular Phone
Onkyo tx904
I think it does really happen that way on some things like that , maybe its the controling IC or a busted resistor inside your amp. and check your speakers too. maybe they are shorting inside that makes your amp malfunction. try too open it or its up to you.
Jan 13, 2008 | Audio Players & Recorders
Audiovox PPC 6700 Logo
93 people viewed this question
Top Audiovox Computers & Internet Experts
Rick
Level 1 Expert
Ekse
Jaagoo
Level 1 Expert
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
