Question about Samsung Renown Cell Phone
Battery wears down too fast
My new Verizon samsung renown battery wears down quickly. Verizon checked the battery and says it's fine
  • 3 Answers
Http://adf.ly/QrPZb
Posted on Jun 21, 2013
    Problem Solver:
  • 22 Answers
Verizon will tell you its okay, because in a way it is. when you first get your cell if you use it before you charge it, it will drastically effect its overall battery life. the solution would be to buy a new battery and to not use your phone until the new battery is fully charged.
Posted on Jul 08, 2009
What is a battery discharge test
To see how quickly it loses juice. If.fast discharge..u need new. Hot weather wears a batt. They only last 3-5yrs. Buy a deepcycle marine battery for strenth n longlife
Aug 30, 2016 | Cars & Trucks
I have a yard cruiser blade clutch engages then slows down when it gets under a load to the point of stopping let cool down same thing
Most likely it's a worn out pto clutch (electric blade clutch) one is a warner brand and one is ogura for this line. but first you should check two things:
1. Belt condition and tension (It should be pretty snug
2. make sure your battery is putting out at least 12 volts, you may try a new battery or have the battery tested for free at a local auto parts store. If they find the battery is low, your charge circuit may have a problem. If they find the battery is fine, and the belt is good, it's probably time for a new clutch. I say check the battery first because even if you replace the clutch and the battery is worn out, it will actually wear out the clutch quite fast. This is a common reason for the clutch to wear prematurely.
Apr 28, 2012 | Snapper Garden
Last week I had spilt water on my phone but I got it in rice fast enough and it was working just fine. But when I tried to send a text message to my friend a couple days ago it locked up now whenever I try...
Rarely does a phone return to "normal" after a bath with the power on. You did good putting it in the rice and removing the battery as quick as you could ... Still, few phones are the same after a power on bath. Verizon isn't just trying to sell you a new phone - they know what they are talking about in this case. You will have to replace the phone or have yours professionally repaired, if you can find a place to repair it for you.
The simple fix: Replace it. Nice as your Chocolate is, it is yesterday's technology + it is not working.
Thanks for your question @ FixYa.com
Apr 16, 2011 | LG CHOCOLATE VX8500 Cellular Phone
18 HP ohv intek engine will not turn over fast enough to crank. will turn over real fast when the spark plug is removed.
Sounds like you have a battery that may be weak, or the battery posts are dirty.
First clean the battery posts, removing any corrosive buildup, rust or green looking
corrsion. Baking powder and water with a steel brush works good for this. You will need
a couple of wrenchs to loosen the bolts on the clamps holding the battery cables to
the battery posts. A pliers and a adjustable crescent wrench and maybe a screw driver
should work. Clean, refasten the clamps and ry again. It should spin over faster,
with the spark plug in. If it does not, still turn over quickly, then your battery may be
needing a battery charge. Charge the battery with a battery charger and try again.
If it still does not turn over quickly, then your battery has a dead cell and needs
to be replaced.
If your battery checks out good, then check the other end of your battery cable
leading to the engine starter. It may be lose or not tight enough. Another problem
that it mat be if al these are good, is that your starter is needing to be replaced.
It is starting to wear out if it slows down with all other componets working good.
If all these previous checks turn out to be good, then your engine may have a problem.
This is then a check that will need to be done by a lawn mower service repair man.
Feb 25, 2011 | Craftsman Garden
Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
May 26, 2010 | Motorola Mobility Boost i415 Cellular...
I760 cdma purchased from ebay usa global with verizon carrier
In order for you to do that you will need to get a Global Phone, every ESN (Electronic Serial Number) is only programmed for a specific carrier i.e. Verizon, if you want to take your phone over to India you will need a Global Phone check out the Samsung Renown or Blackberry Tour/Storm/Storm2
Apr 02, 2010 | Verizon Communications Samsung Alias Cell...
I have a Samsung Renown. I want to change from
by law they have you to give after one year subscribtion
Mar 10, 2010 | Samsung Cell Phones
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Battrey fast discharges
dear, there are two possible reasons of battery down.. 1st is that your battery is not ok and the other is your phone's charging IC is going to drain it.. so check the battery with other set or try with new battery in your phone.. regards, hope it will fix the issue so dont forget to rate it...
Jun 04, 2009 | Samsung Cell Phones
Initial Programming Needed on Samsung Renown with Verizon
Verizon customer service isn't always very helpful, but the verizon website can be. Try clicking phones&devices under the support section. Once you select what type of phone you have, you will see that it says "activate phone" on the left side of the page. This will guide you through the activation of your phone, and the instructions are pretty clear. Hope this helps.
May 21, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Samsung Renown  Cell Phone Logo
189 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
