Question about Compaq Presario R3000 Notebook
Ac charger will not work when computer is on. It will recharge the battery when computer is off. Have replaced the charger and continue to have same problem with all ac chargers.
  • Anonymous May 11, 2009
    i have the same problem with mine, ive tried everything, so now am just going to change the motherboard, hopefully this will fix the problem
    Scholar:
  • 89 Answers
Tray and remove the battery from the system, leave the system plugged in with the battery out. Does the system boot? If yes, then the system board has enought power to turn the computer on, your board is most likley fine. however that may not be the case and it could be the board I would look at replacing the battery before you replace the board.
Also try and use the power adaptor that game with the unit, this will help ensure that your system will not get to much volts and fry a cap on the board.
Hope this helps.
Posted on May 26, 2009
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Jun 28, 2010 | Campbell Hausfeld CC2300 Cordless 230 PSI...
My computer does not reconize my ac adapter
If the BIOS cannot ID the charger, the battery will not be charged. Cause: There is a fine wire in the middle of the canon plug to the computer, that sends an ID of the adapter to the BIOS. If that pin is bent or broken, then the system will be powered, but the battery charger is disabled. If another AC adapter for a Dell D-series is available, see if the issue goes away with diferent adapter. If no adapter is available, they are <$50 on Ebay. If you replace the AC adapter, and the issue still occurs, then you'll need to replace the motherboard.
Jun 14, 2009 | Dell Inspiron 1501 Notebook
Canon Powershot A430 - can i charge batteries through AC
The A430 is a camera, not a battery charger. If you want to use rechargeable batteries then you must use a separate charger. Battery chargers should be available at just about any department, electronics, or office-supply store.
Apr 30, 2009 | Canon PowerShot A430 Digital Camera
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Need battery charger
You can buy it to any electronic or computer shop nera you like Bestbuy , Radioshack or any other store just give them model of your device and they will be able to provide you that....
Nov 12, 2008 | kawasaki PVS1080
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
I have a brand new "my musix"mp3 player pd-6070,and i want to know how do i recharge the battery on it.thanks
you have to charge it by putting it in the USB port on your computer, but I am looking for an a/c charger if anyone knows where i could get one that will work with this! i got two off Ebay and neither will charge it! they charge my daughters Craig MP3 player but not my musix!
Feb 12, 2008 | MyMusix PD-6070 MP3 Player
Compaq Presario R3000 Notebook Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
