Question about Radio Communications
I put red to black and black to red by accident now it won't work
  • Jim Scott May 11, 2010
    have you checked the fuses at all ??
  • 22 Answers
You probably blew a little Diode. Check where the power comes into the radio you should see a diode in the general area it will probably be cracked if not you will have to put a meter on it to test continuity. O yea check the inline fuse first...
Posted on Apr 23, 2009
How does the brake work?
there have been countless accidents where unattended strollers have run away causing ***** to the child
the idea that you have is to prevent that from happening if you fail to apply the wheel brake
to do anything to prevent ti from working as designed will result in legal charges being place on you in the event of a accident involving injury to the child
it is not intended as an incinvience to you but to ensure the child's safety when you are inattentive
May 17, 2017 | Schwinn 13-SC906A Free Wheeler - Red/Black...
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Car won't start powerwindows won't work powerlocks won't work all fuses are ok I think when car was boosted they put cables on wrong terminals I tried boosting it will crank but will not start...
check your ignition fuse and relay fuse.also check your master fuses located on the fire wall they are the ones that run from your nattery to your maine master fuse.follow the battery cable the red one all the way to the fire wall and from there it gos to the starter you may have burned thoses fuses out remove the black fuse cover
Sep 09, 2011 | 2004 Chevrolet Impala
Have a 95 ford mustang. Had to make a sudden stop, I put car in reverse and when I put it back into drive it died. Ran the battery down trying to restart. It was an old battery so I replaced the battery,...
You may have tripped the inertia switch. It's a small black box in the trunk with a red push-button; it is designed to pop if the sensor registers a certain g-force and kills power to the fuel pump to prevent gas from being pumped out after an accident. Look for that behind the trunk interior panels.
Very good problem description btw.
Jul 11, 2011 | 1995 Ford Mustang
I plugged the car stereo and it looks like has power. A red light is on and I can put a CD on it and take it out but the rest doesn't work.no lights, no sound, nothing.It could be broken or just wrong...
most likely an internal problem but check the wires first, the yellow off the radio should be the 12 v ignition and the red should be the 12v constant, black ground of course, also if you had wires you didnt need to hook up make sure they aren't by accident
May 22, 2010 | Car Audio & Video
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I accidently put red to black and black to red on 12 volt
The fuse is probably blown and will continue to blow until the protection diode inside the radio is replaced. Do not remove this diode, have it replaced, as it saves the rest of your radio when you hook it up backwards. Do not try a larger fuse. A standard CB radio should be fused at about 2 amps. amduke@mail.com or 804-855-4747 I can fix it if you'd like.
Apr 18, 2009 | Radio Communications
I am trying to wire up a new bell box to an exisiting panel the wiring layaout is as follows panel : 19.20= strobe ( with link ) T A (SCB) DB (BELL) BOX : HOLD HOLD- TG- STB- RETURN I have...
bell wire is color coded ,red terminal red wire ,white terminal white wire , when connecting theese wires be careful not to staple into one by accident because it will definetly cause a short , don,t worry it won,t cause a fire because it is low voltage , you can stick the wire in your mouth and still not get a shock , but seriously the wire that comes with theese machines is flimsy and can get broken fairly easy , just double check your wiring , infrared sensors are white and black and must be put in the proper stick in terminals on the machine , Here is your configuration from left to right ,RED/WHITE /WHITE,BLACK , remember do not take the white wires from sensors and stick them into the white terminal next to red because that one is for the bell and the whit thats next to the black is for the infrared sensors ONLY theese two cannot be crossed and always keep the two wires together till your ready to wire to the machine because if you seperate them before they are impossible to distinguish from one another when it comes time to wire it to the opener ,Hopefully i was able to help you ,if you have any more questions i will be happy to answer them , lets get this thing working Sincerely Glenn
Oct 31, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Radio Communications Logo
81 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
