Question about ASUS Eee 4G Notebook
Bought new notebook with vista, but no passwords for user?
I bought a brand new asus notebook m51v with vista premiun. it has 2 existing user profiles, but i dont know the passwords and cant login/
  • Chris Hingee
    Chris Hingee May 11, 2010
    A brand new notebook should not have any existing user profiles. Take it back to the shop and get an unused one or at least get them to reinstall the laptop back to the default/unused setup.
How do i put a code on an asus pc
If you are using windows XP , vista or windows 7 here is what to do .
1. Open your control panel and click on users and accounts.
2.click on the account you want to put a password on.
3.click on ''create a password''.
4.type in your password.
Dec 06, 2012 | ASUS Eee 4G Notebook
Tip
Asus Password Reset with 3 Easy Ways
"I forgot my <b>laptop password Asus Eee</b>! It is important to unlock or recover the lost Asus password. I do not want to reinstall or reformat my Asus PC for vital files on it! Can anyone help my <b><a href="http://windowspasswordrecovery.net/"><u>Asus password reset</u></a></b>...?" Such Asus password problem can be heard usually. <br /> Fortunately, there are efficient ways to successfully reset Asus Windows 7, XP, and Vista laptop or netbook password. According to these common troubles, we now list 3 helpful suggestions on <a href="http://windowspasswordrecovery.net/"><b>Asus laptop password reset</b></a>. If you have met the similar problem recently, you can take these ways for reference.<br /> Solution 1: <b>Reset Asus laptop password</b> with administrative accounts<br />Accounts with administrative rights and privileges can help us to <i>override Asus password</i>. Take <i>Asus XP</i> as example, there is a default Administrator account without password. Then we can remove the password Windows XP if we don't set a password for the account.<br /> Step 1: Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.<br /> Step 2: Start -&gt; Control Panel -&gt; Administrative Tools -&gt; Computer Management -&gt; Local Users and Groups -&gt; folder Users<br /> Step 3: Right click the account user name which password was lost, and then click Set Password -&gt; Reset password -&gt; keep New Password and Confirm Password blank.<br /> Step 4: Right-click locked account and select Reset password.<br /> Step 5: After finished, restart PC and login.<br /> Solution 2: <b>Reset password Asus</b> with Ophcrack <br /> Ophcrack is a free Windows password recovery that breaks Windows LM hashes password based on rainbow tables. It only works for passwords that are of less than 14 individual characteristics.<br /> Step 1: Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.<br /> Step 2: Insert the CD into the locked computer and restart it.<br /> Step 3: When computer starts, we have to press the correct key to enter the boot menu. <br /> Step 4: After select the drive that the CD is in at start menu, do as the following instructions.<br /> Solution 3: <b>Reset Asus password</b> with Windows Password Recovery tool <br /> It is said we can solve our Windows password recovery problem with a third party toolkit successfully. As it is proven, <a href="http://windowspasswordrecovery.net/"><b><u>Ainorsoft Windows Password Recovery</u></b></a> is well used to recover lost Windows password for many PC users. Actually, the program really did a good job with a bootable CD/DVD or USB Flash Drive. We just need to download and install the <i>Ainorsoft Windows Password Recovery</i> on an accessible PC and then follow its "How-to-use" instructions to help us solve our problem easily.<br /> Now, we can deal with our <b><a href="http://windowspasswordrecovery.net/">Asus password reset</a></b> problem with any of the above listed methods. We just need take ease with our locked Asus Eee laptop password based on Windows 7, XP, Vista, etc.<br /> <i>Source</i>: http://windowspasswordrecovery.net/article/asus-password-reset.html<br />
on Apr 27, 2011 | ASUS Eee 4G Notebook
Just bought a Eee PC 1000HA from a pawn shop, and when I charged it and turned it on, it goes to a bios screen that says at the bottom that the hard disk is locked. It ask's for user password or press ESC...
When buying things from a pawn shop, it is wise to check it out to see if it functions properly before you purchase it.
Hard disk passwords cannot be broken/hacked, and putting a new hard disk in the laptop may not work, this depends upon the BIOS password setup.
I suggest you try and return it and get a refund.
Apr 08, 2011 | ASUS F3Jc Notebook
How do i reset the bios password
How to recover your forgotten laptop BIOS password? There are 3 methods, each method has its strength and weakness but I am going to talk about the 2 easy methods that works across the board for everyone. Here they are:
Method 1 – Remove BatteryFor desktop user, open up your computer casing and look for the battery. Remove the battery for approximately 5 minutes (maybe longer, depending on the motherboard) and slot it back. By removing the battery and deprive the motherboard’s flash memory of power supply, you are essentially resetting the settings back to default when the existing data in BIOS are cleared.
laptop_battery_desktop_bios_remove_reset.jpgThis method works well for desktop, however this is not practical for laptop user unless the warranty expired long time ago. This method might or not not work, it depends on the type of motherboard.
Method 2 – Reset CMOS With SoftwarePC CMOS Cleaner is the best CMOS password reset software, it works setting the BIOS to the default state or revealing the password.
reset_bios_cmos_password_motherboard_remove.jpgreset_bios_cmos_password_motherboard_remove2.jpgPC CMOS Cleaner is an easy-to-use tool to recover, delete, decode and display the superior passwords stored in BIOS whatever the brand is. Most types of BIOS are supported. It’s an bootable CD that runs on x86 and x86_64 computers. No need to pay expensive fees to experts. It’s a useful tool for users to get their lost BIOS password back, or clean passwords from an old computer bought from others.
  • Support all x86, x86_64 Personal Computers.
  • Support most BIOS, such as: AWARD, AMI, Compaq, Phoenix, Samsung, IBM, Compaq, DTK, Thinkpad, Sony, Toshiba and so on.
  • Display the superior passwords of the BIOS .
  • Remove BIOS password(will set the BIOS to default status, need reset date).
  • Set the BIOS to default state
Feb 26, 2010 | ASUS V2S-B1 (V2S-B1 + TGS-BACKPACK) PC...
Laptop dvd player stuck on region 1 need 4 for
Try changing the region by right clicking your DVD drive in explorer and select properties, go to hardware tab, select your DVD brand and type, click properties, go to DVD region, and change the region.. Just remember, any DVD only allowed to change the region for about 4 times, after that, you can't change the region anymore..
Dec 23, 2009 | Toshiba Satellite A135-S2276 Notebook
I need help to turn on my blue tooth..please
You probably need to use a function key to start it up ? go to asus site and find the function key that supports blue tooth . ie : F 2 - OR F 3 ...ECT
May 30, 2009 | ASUS R1F Tablet PC
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Good morning,i forgot the password on my asus 4g,help!
Hi, Just Press Alt, Ctrl and Delete at the same Time and Type 'Administrator' into your Account or user name and the password by default is nothing so don't type anything here and press enter and this sould give you access to your computer. Go Into control panel>User Accounts, and create a new account because you need your old password to change it. If this doesn't work Type Guest as the user name and the password will either be guest or it doesn't have a password. from here you cannot change or modify accounts, but at least you can use your computer until you get it fixed. and if this doesn't work take it into a computer technitian to look at it.
Hope This Helps
Nov 20, 2008 | ASUS Eee 4G Notebook
Ref laptop
Dear Jo,
I hope your operating Sytem is Microsoft Windows Vista Home Premium.
Please re-install the Windows Vista Operating System and you choose upgrade option ( PLEASE DON'T CHOOSE NEW INSTALLATION). during the setup you can create new password for 'Administrator' user and you will not possibly loose your data.
NB: Please don't choose "NEW INSTALLATION" because if you select this option and continue setup all your data existing in hard disk may loose.
All the best from FixYa
Oct 23, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
ASUS Eee 4G Notebook Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
