How to alignment adjustments on roland sc 540?
How do I change MIDI Channels to coincide with my MIDI controller
Your best bet would be to ask Roland. Here is their link-
https://www.roland.com/us/company/contact_us/ Roland Company Contact Us Contact Us
Feb 27, 2016 | Roland Music
Roland sj 740 service manual
roland SJ-740 ink not filled, how to escape this setting
Mar 13, 2013 | Roland Printhead FOR SC-540 / SJ-540 /...
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
I have a new Dell Inspiron 1525 with Windows Vista. I am trying to install my Band in a Box system on it. I can not find a driver to run my Roland Sound Canvas SC-8820. Can you help.........
The Roland support page for the SC-8820 has drivers, including those for Windows Vista:
http://www.roland.com/products/en/_support/dld.cfm?ln=en&dsp=0&iCncd=722
Sep 25, 2008 | Computers & Internet
I have a Roland Versacamm and as it's printing an image that is supposed to be a rectangle shape 40"x60"...as it prints out the image is not straight it actually looks wavey like a flag? The printer was OK...
this sounds like a scan motor error. clean encoding strip and test. If still wavy remove scan sensor the one that reads the encoder strip, clean with alcohol, replace and test. if still bad replace encoder strip and the eye that reads it.
Aug 02, 2008 | Roland Vs-2000CD Digital Studio...
I have lost my tv remote for my syphonic tv
One website gives instructions on how to use the AUTO CODE SCAN feature of your remote, even if you don't have the code numbers. Take the following steps to access this info.
Step 1) Type REMOTECODELIST.COM into the Google searchbox, and click on GO or SEARCH.
Step 2) Once you are on the website, scroll down the page until you see JENSEN in big red letters, on the left hand side.
Step 3) Look under JENSEN for SC-540 ( in purple letters), and click on SC-540.
Step 4) Look on the right side of the page for instructions on how to do an AUTO CODE SCAN.
Hope this helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 15, 2008 | Symphonic ST420FF 20" TV
371 people viewed this question
jasbo
jasbo
