Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Fisher & Paykel DD603 Error code F2. My top dish draw is showing the error F2 , I have taken out the baskets, spray arm, propellors. The metal shaft is completley frozen, I can't move it at all. I see other posts say to wiggle it to free it but that doesn't work here. Can I get a copy of the service manual too? We are along way from a repair man to come look and I like to try myself before spending more money on it. My e-mail is m.oakden@hotmail.com. Thanks.
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
Master_Tech
  • 770 Answers
SOURCE: I had an "f2" error code on Fisher Paykel DD603
i will but need your email address
Posted on May 20, 2008
Master_Tech
  • 770 Answers
SOURCE: Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Posted on Aug 28, 2008
SOURCE: DD603 Service Manual
Try the Fisher Paykel web site
http://www.fisherpaykel.com/global/customer-care/product-manuals.cfm
Note that there are different language versions before you download.
Posted on Nov 22, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel DD603 Disher Drawer Service Manual
You can get fisher paykel service manuals here:
http://fisherpaykelparts.net/index.php
Posted on Dec 11, 2008
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
Jan 21, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
There is an error code f2. How can I fix this?
The F2 code= siezed pump. To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover. Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. The impeller may have come off and lifted off with it the brown ring leaving the rest of the pump stuck in the hole. So be careful here, get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go. Yours could just be stuck of course. A clean may do the same trick.
Feb 16, 2010 | Dishwashers
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I am getting an F2 error code on an DD603.
there is something jamming in the rotor , lift the spray arm and try spinning the blue fan , or if u havent used the btm drawer in ages it is a seized rotor , around 80 $ to buy new
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
520 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
