Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Set top box installation
Don't know what a RF cable is? Just thought you plugged it in and that was it. Don't get the instructions.
  • 297 Answers
RF is the normal round coax cable in black.
Further you need to select your video channel on TV to watch the set top box RF signal. Usually you change the RF channel frequency also on these things. If you don't know channel number let TV scan it.
Posted on Apr 18, 2009
How to Activate a Comcast Cable Box?
Follow the instructions on the displayed screens. Or, if you would
like to activate your new XFINITY TV service using your phone,
please call 1-888-270-6445. 1. Connect the coax cable from your
cable wall outlet to the Cable In/RF In connection on the back of
your Digital Set-Top Box .
Oct 19, 2016 | Televison & Video
How do I reset error code SC548
25685181-yl5nsd0dwyytd1n2wv4v20hl-5-0.jpg OR
Sponsored Link Shop Bulk Wire & Cable
Network, Telephone, Coax & A/V. Quantity Discounts & Same Day Ship!
showmecables.com/Bulk-Cable STEP 1 Purchase the RF modulator at an electronics store. The modulator is used to connect your older television to cable.
STEP 2 Plug the RF modulator in a power outlet near your television. It is best to plug it near the television to allow for easy access.
STEP 3 Connect your television to the RF modulator by inserting the one-prong cord that is on back of your television. Insert the cord in the slot on the modulator that reads, "To TV." On older televisions, this cord is the only cord in the back.
STEP 4 Connect one end of the white one-prong cable to the cable box and the other end in the RF modulator. Connect it into the modulator in the slot the reads, "ANT IN." Usually, the cables are provided by the cable company--the technician uses them upon installation. This particular cable may run along the side of the wall to your cable box.
STEP 5 Turn on the cable box and the television set. Everything should be working properly. On the RF modulator, choose the channel for the television (either channel 3 or 4). The modulator turns on when you plug it in.
May 08, 2015 | Office Equipment & Supplies
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have Powerspec tv , after turning on the TV ,no pictures after a second?
> if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
> same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
> Check the connecting cables like RF-cable,Audio-Video cable ,Power cable and others are properly arranged and connected with their proper plug & ports and sockets.
Now ur problem will be solved. Bi.....
Nov 29, 2009 | Winbook Corporation PowerSpec MCE 410 PC...
I need a diagram of how to set up the analog converter box or instructions.
I am posting the instructions of how to set up the analog converter box :-
Hope it will you.
· Things you’ll need:
Analog TV, antenna, two coaxial cable, and converter box
· Instructions:
Step 1
Unplug coaxial cable on the back of TV "antenna in" (RF) port
Step 2
Insert coaxial wire into the "antenna in" on the converter box
Step 3
Use second coaxial wire and plug in the converter box, "out to TV" port. Plug the other end into
“antenna in" on the TV
Step 4
Power on the converter box and TV. Change TV channel to 3 or 4. Follow on screen instruction to
Complete setup.
Step 5
After setup you will begin to see more channels than before with better clarity. Some stations will broadcast two or three channels. Enjoy
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Televison & Video
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Dear FixYa,
We have installed a Grundig STB but cannot figure out how to use our VCR or DVD Player.
Do we need extra sockets ? Of is there a simple solution we have missed.
Sincerely
Suzann T.
Jun 22, 2008 | Televison & Video
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
377 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
