Windows will not start up
I have a Toshiba Qosmio G40-12C laptop. Yesterday,after using the computer I went to shut it down. It said that it was loading seven new updates and to wait until that was finished - not to turn it off. Unfortunately,it remained stuck in the first update mode for over one hour - so in the end I turned it off manually. When I tried to restart it, I get a pane headed 'Windows error recovery', saying Windows has failed to start, due to perhaps a recent hardware or software change. It gives me two options: 1.'Launch startup repair (recommended)',or 2.'Start windows normally'. Naturally I chose the first option, but after saying "Windows is loading files', a 'Systems Recovery Options' flash comes up stating that 'The installed programme cannot start. Click okay to turn off the computer'. Next, I try the second option 'Start windows normally'. That brings up some blue writing that disappears so quickly I cannot read it. The computer then **** down and restarts by itself and I am back to square one with the two options. Can anyone help since I do not want to use the Windows recovery disk because I am sure I will lose all my work and programmes. Thanking someone in advance.
  • 5 more comments
  • Jerry Haylins Apr 18, 2009
    Thanks for your quick reply. Yes, I am in Advanced Boot options, which gives me different safe mode options, alone or with networking or with command prompt. I have not chosen one yet.
    It went through a list of drivers - then the same blue writing as before came up, which is too fast to read and it shut down and restarted, like with the 'Start windows normally' I had earlier.
    Can't find that one. I will list the others I have for advanced options for Vista:
    Enable boot logging
    Last known good configuration (advanced)
    Enable low-resolution video
    Directory services restore mode
    Debugging mode
    Disable Driver Signature Enforcement
    That's them all. I have tried to read the quick pane. It says it has detected a problem and is shutting windows down. There are a series of numbers at the very bottom of the page under 'technical information', but it goes too fast to read them.
    Yes, it is Vista
    I have a disc called 'Product recovery' - Windows Vista Home Premium 32-bit.
    Yes it is a recovery disc.It says on it to keep the F12 key pressed when installing the disc. I have done that, but even though I hear it start up, it then stops. The screen stays black with just the Qosmio logo and no instructions. Sounds like it has had it.
    yes, I do, jhaylins@hotmail.com.
  • 227 Answers
Have you tried pressing F8 as the computer is booting? Press it repeatidly as the computer starts. If the computer is not that far gone you should get a Multi-options menu-choose safe mode, then post back after you get into safemode. Post back if you cannot get onto safe modeand let me know the results
Posted on Apr 18, 2009
  • 7 more comments
  • Arthur Hoffmann
    Arthur Hoffmann Apr 18, 2009
    use with command prompt
  • Arthur Hoffmann
    if any errors result please give details
  • Arthur Hoffmann
    OK try- the same F8 procedure but select (I think it is called) selective start up, should give you a choice for each driver to load- as a yes or no selection, select no for each one. it MAY fail it may NOT but note which driver it fails on, if it fails
  • Arthur Hoffmann
    Can you tell me your Windows Version ?
  • Arthur Hoffmann
    Do you have the vista CD?
  • Arthur Hoffmann
    I think that may be a system restore disk. In which case you would loose all you data. But we will take it as far as we can without restoring. Insert the disk, reboot the computer. DO NOT select any options without posting what is indicatedm UNless you can determine your next key press will NOT start a system restore.
  • Arthur Hoffmann
    In short I am try to Rebuild the BCD store by using the Bootrec.exe tool which is contained on a bootable Vista CD
  • Arthur Hoffmann
    Let me also ask: On the computer you are using, do you have Windows Live messenger
  • Arthur Hoffmann
    OK Load you Wnidows live and accept me as a contact
Qosmio f60 fan goes on high speed and freez. It keep freezing.The only way to reboot it is to hold down the power button to turn it off and then turn it back on.
I have the same "computer" qosmio f60. I've replaced the hard drive, installed a new window 7 OS, changed RAM paging, power options, run the things with a fan pointed at the computer fan.
The fan goes to high speed and the HDD LED unblinking. I've brought the laptop to two computer shops whose owners knew less about computers than I did. I tried to go to a Toshiba recommended shop in Toronto except they changed to Apple-service only. I tried phoning Toshiba, they just want to change 4 bucks a minute for technical assistance. I've had this Toshiba-thing going on 3 years with the troubles starting after the first year. No one cares about this problem. If I see a Toshiba factory I'm going to chuck this red brick of cra through the window.
BTW it's not a virus or rootkit. I had to learn how to partition a HDD sector through some crazy BIOS program before installing windows. There's no virus or rootkit that's causing this problem.
It's mostly been freezing on me with games.
Aug 31, 2013 | Toshiba Qosmio G15 Notebook
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
How do you reconnect wireless network connections on toshiba qosmio f25-av205 using windows xp have drivers but the wizard says diconnected
Ok, first you want to right click on my computer, select manage, services, and double click on wireless zero configuration and select automatically under startup type and click on start. Double click on the icon for the wireless zero configuration next to the clock. Select the correct wireless connection and click connect.
May 17, 2010 | Toshiba Qosmio F25-AV205 Notebook
My computer ask to be reboot how do i do it?
This just means shut down and restart.
Just click Start>Turn off computer, and when it has shut down turn it back on.
It's as simple as that.
Mar 26, 2010 | Toshiba Qosmio G15 Notebook
Hello! Ive got Toshiba Qosmio X300-11W laptop the
Use the correct video driver. Maybe you installed the incorrect video dirver. try installing driver from cd.
Aug 13, 2009 | Toshiba Qosmio X305-Q708 PC Notebook
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
I have a Toshiba Qosmio G15R and I need drivers
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
Blue lines on Display seen.
that is easy just go to rooftop of the building and throw you loptop ok
Oct 19, 2008 | Toshiba Qosmio F25-AV205 Notebook
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
