Question about Canon FAXPHONE L80 Laser
PAPER FEED The left side of the paper comes out crumpled and a black mark 1" wide near the left edge like a roller is not rolling. This is the fax or the duplicate copy, not the origional copy.
  • 1 more comment
  • hijacker Sep 21, 2007
    Had already replaced toner cartridge. Black line looks like a roller is not turning, just skidding. Thanks for trying.
  • Anonymous Mar 21, 2014
    Paper is stuck partway through the copier following attempt to copy
  • Anonymous Mar 31, 2014
    i WANT TO FAX BUT NOT SURE HOW TO ATTACH THE COPY TO THE COVERPAGE
  • 163 Answers
The drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Posted on Sep 21, 2007
  • Anonymous Sep 22, 2007
    you should also check the heater sleeve may be it is tear
6ya staff
SOURCE:
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
Paper problem
That is a common problem especially if you are using a thin paper and an aging machine.
The feed rollers tend to develop dusts which causes the thin papers to slide or crumple in the middle.
Solution would be to clean or replace the feed rollers. Contact your supplier for a service or order service parts such as the feed roller.
Hope this helps. Thank you for using Fixya.
Jan 08, 2010 | Konica Minolta bizhub C250 All-In-One...
Print head slams side to side against little black movable posts.
Sounds like your printer needs to be serviced. Would seem to me like the rollers are dirty and needs cleaning. There's also a possibility of dust and paper bits being in other areas of the paper path blocking it.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Changing paper on HP Designjet 5500 Plotter
Step 1. Install a roll of paper on the spool, and install the spool on the printer. The fixed end of the spool should be on your right side as you face the printer. The paper should come off the top of the roll.
step 2. open the window and support it with the built in support. Lift the blue handle, located just to the right and above the spool adjacent to the black roller.
Step 3 Pull out about a yard of paper and feed it in front of the black roller and in back into the printer. You really don't need to be precise, the path will accept the paper. Keep pushing the paper until it comes up the the top, then pull the paper from the top.
Step 4 If the edge of the paper is cut square just line it up with the front edge of the printer and on the right there is a blue edge guide mark. If the paper has not been cut square then pull it out far enough that it reaches the spool and line the left and right edges up with the roll and also the blue line.
step 5 Lower the window and the handle. The printer will attempt to install the paper. Respond to the questions that appear on the screen and you should be good to go.
I can walk you through it by phone if you need more help.
Jan 28, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Lexmark e250dn
Over time the rollers get slick and hard. If one side is slick and the other edge is not, it will grab paper sideways and you get a paper jam. Get some rubbing alcohol and rub the rollers (completely all around) to get some debris removed. Some rollers require a slight rubbing with an abrasive pad.
Feb 18, 2018 | Lexmark E250dn Laser Printer
Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Nov 09, 2008 | Sharp UX 108 Roll paper Thermal Fax
Paper feed problem
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Sep 11, 2008 | HP DeskJet 6540 InkJet Printer
Canon i9950 feed issues
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon FAXPHONE L80 Laser Logo
98 people viewed this question
Clive
Clive
old marine
old marine
Ekse
