Question about Dell Dimension 5150 Intel Pentium 4 w/HT Technology 3.0GHz,800FSB,80GB HD,512MB DDR2 RAM, CD-RW/DVD ... (D5150) PC Desktop
How much Ram am I using?
I have installed 4 * 1GB ram and, on start up, set-up shows each slot contains 1Gb as expected. However I also have PC Registry Mechanic running and this says I only have 2 GB of Ram! Which is right? Am I getting the proper use of my 4 GB?
  • rjohnstone Apr 22, 2009
    This solution would explain why I get less than 4 Gb, maybe as little as 3Gb, but not why I only get 2Gb. I would like to understand this before I throw good money after bad and upgrade from XP to Vista.
  • rjohnstone Apr 23, 2009
    Windows itself says 3.5 GB
    President:
  • 2,992 Answers
Unless you are running a 64-bit version of XP or Vista, Windows will not report the full 4GB. It's because of the way the program addresses and uses RAM. Here is a page that gives a little explanation. The bottom line is that if you want to get the full use of 4GB of RAM you need the 64-bit operating system.
Posted on Apr 18, 2009
  • Apr 22, 2009
    How much RAM is Windows itself reporting?
  • Apr 23, 2009
    Says something about the reliability of PC Registry Mechanic, doesn't it?
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
I WILL REPAIR MY COMPUTER
Upgrade your RAM into 1GB or more, currently you are using 512MB which causes your system slowdown. On that model look for SoDIMM RAM with the DDR2 slot with 1GB or more. If you can see 2 memory slots, just buy additional RAM then put it on the blank slot.
Oct 06, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Cannot get laptop to recognize upgraded ram. upgraded 1 of the slots to 1gb. the othe slot has 512mb. Laptop only shows 1gb ram.
did you install the same speed ram? verify that the 512 stick is still securely installed.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | Gateway MT3705 Notebook
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
I would like to add ram, do you know how many slots and how much memory I can add to this computer? Thanks, Cyn
Your machine supports, DDR2 SDRAM or (DDR2) type Ram, maximum 2GB and has two Ram Slots.
Good luck.
Thanks for using FixYa.
Aug 19, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Install memory not showing total only half
Hey,
it should show in the bios as 2048.
looking at the details of the motherboard
Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 2 x DIMMs Supported RAM speeds 400 MHz
Got the right speed ram etc?
Thanks,
Ekse
Feb 20, 2009 | Computers & Internet
Trying to upgrade RAM - won't boot after new RAM installed
Install the RAM on memory slot and Switch on your system and go to BIOS settings. There you can check whether your RAM is working properly or not. If it shows no memory installed then the RAM Chip may be damaged.
Jan 08, 2009 | E-Machines T6520 PC Desktop
Heating problem
Intel D102GGC2 Motherboard
i am having 1GB Ram in Single slot,when I add another 1GB ram in the other slot the memory shows only 896Mb.The processer is dual core.
Dec 05, 2008 | Intel D102GGC2 Motherboard
Computers & Internet Logo
108 people viewed this question
Alun Cox
