Question about Nintendo NES Console
Nothing happening when hit power button....
I just bought a nes from ebay- the item description says 'guaranteed to work' i plugged it in, connecting the rf switch to the back of my tv, and my cable to the end of the rf switch- connected the other ends of the cords into the corresponding spots on the back of the nintendo- hit the power button, nothing happened- not sure what to do
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Posted on Sep 18, 2007
6ya staff
SOURCE:
I bought a DS Lite on Ebay but it has problems. In the item description it said that the buttons didn't work, but I can't get it to turn on. I flip the on switch and the green light comes on but nothing...
Way did you get a DS Lite from Ebay? Don't you know that stuff on Ebay is always broken or worse?! throw away the ********** thing and go to the store and buy one! :(
Jan 03, 2011 | Nintendo DS Lite Console
I bought a NES on ebay, connected it correctly as far as I know, but I press the power button and nothing happens. Please help! Could it be the adapter plug?? Thanks
Well it might be the ac adapter thats causing the problem but it could be a power system failure but most likely the first choice is the answer.
Dec 16, 2010 | Nintendo NES Console
Hi when i hit the power button on my hp laptop the button blinks and nothing happen
This usually happens if the battery is completely dead and needs recharging for awhile. Unplug the battery and try to turn it on if you want to test this immediately.
Otherwise the power adapter might be malfunctioning. These are fairly cheap on Ebay (10-20$) I have bought one of these and it works just fine. But you can also buy brand name ones at computer retail stores for exorbitant prices of 80-100$.
Sep 29, 2010 | HP Pavilion dv9700t Notebook PC
We've just bought a snes vis ebay but we can't get it to work. I'm sure it's very simple. we've connected it to an old tv and have the Av channel on but nothing. The power button on the console is glowing...
Well try cleaning the gamepacks out with qutips and rubbing alcohal then or the worst case is that you guys have purchased a broken console or have gotten ripped off then.Buy from jjgames or lukie games them because theese are reputable sellers.
Jun 05, 2010 | Nintendo Super NES Console
My snes is broken
Well I would buy a new super NES console then and yes people have had bought broken items off of ebay or kijiji for parts to fix their console so you could buy a new one from a repuatble seller and sell yours as broken then.
Sep 20, 2009 | Nintendo Super NES Console
Won't power on
Well those 3 way adapters are bad news then use an offical NES ac adapter for ensured quality.
images?q=tbn:and9gcqetqvc5gikbddemes5qps6piaegwqsqn7hupt1di5fscwfoqzeer9mmq
Apr 21, 2009 | Nintendo NES Console
I just bought a lg vx7000 about 3 weeks ago on ebayexpress.com and it just turned off on me, but its not turning back on. the only way my fone will work is if it is connected to the charger, if it is...
Hello.
It seems there is either a battery fault, i.e need a new battery or there is a battery connection problem. either way It's best to return it and ask for either a replacement or your money back. If you paid via paypal you have 60 days to file a claim for an item not as described if the seller is unhelpful.
Oct 05, 2008 | LG VX7000 Cellular Phone
Insignia ns-dvd1 player won't turn on/off, won't open
I had the same problem. Unplugging it and plugging it back in fixed it.
Apr 06, 2008 | Televison & Video
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Sep 17, 2007 | Nintendo NES Console
Nintendo NES Console Logo
289 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
