my scanner it is not new so I do not have the using manual.I have plugged the scanner and I added one cable that assures the connection between them but on my computer I can see the difference.where should I start from?thank you very much and I will wait for your answer
First if you have a software CD with the drivers on it run it before plugging in the usb/ or included cable with it. Next if you do not have a CD go to the manufacturer's website and download the drivers from the support section using the model of your printer/scanner .Save it on your desktop or your documents so it will be easy for you to find then locate it and run it but don't plug it yet till you get prompted by the system.....Good luck hope it will help.
Was this helpful?
Yes
No
Popular Solutions for Agfa SnapScan 310 EPP Flatbed
When trying to scan, I encounter an error code: 2,178,0 and message "Scanner driver will be...
(More)
When trying to scan, I encounter an error code: 2,178,0 and message "Scanner driver will be closed". The lamp is lit but scanning cycle aborts before light can move thru it's scan cycle. I don't know if the lamp is somehow an issue. I have reinstalled the scanner with a recently downloaded driver; Windows shows "device working properly". Scanner worked fine for over 2 years before this started.
I need a driver for my Scanmaker III scanner for xp. I getting a message that the one I downloaded...
(More)
I need a driver for my Scanmaker III scanner for xp. I getting a message that the one I downloaded needs to be updated and when I try to open Twain in Photoshop, it restarts my computer. Help! Keith Droste, Anaheim, CA
Print has lines on it. Have cleaned print head a number of times but nozzle check pattern still has...
(More)
Print has lines on it. Have cleaned print head a number of times but nozzle check pattern still has missing segments.
