Question about Sanyo Televison & Video
Vertical is 3/4 of normal size
I have a Sanyo cm29kf81a tv, the vertical is 3/4 of normal size, what could be the problem. PLS help !!!
  • Henning69 Apr 20, 2009
    This problem started after a lightning storm, looked like a surge came via the power as my power to my house was off as well. biggest problem is that i don't have a schematic for this set!!
    Sergeant:
    Champion:
  • 318 Answers
I have had this type of problems,
check the electrolitic capacitor, charge, if it does not improve change a verticle ic.
Posted on Apr 18, 2009
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
I HAVE A SANYO MODEL 31590 NO PICTURE SOUND JUST A LINE IN THE CENTER
hi..hope this help you....a horizontal line in the center is an indication of defective vertical IC...its looks like a tab w/ 10-12 pins and has heatsink...your TV would works out fine when you replace the IC....but its better if let a technician replace this....pls. don't forget to rate and vote....thanks...
Feb 17, 2011 | Sanyo DS31590 31" TV
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
MANUAL FOR A SANYO CM29KF81A
All you got to do is ****** and just read the dang on directions matbe if you look closly you find wat your looking for
Jan 08, 2009 | Sanyo Televison & Video
SANYO MODEL #DS13204, DS19204, DS25204
Do you have a user manual? Look for the instruction how to reset your tv. Try to plug your tv to other outlet, Chech the AC voltage if compatible to your tv. If dosnt work you need a repairman to fix it.
Jan 11, 2008 | Sanyo DS13204 TV
Sanyo 32" Tv about 4 yers old problem
Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
Vertical height oversize
The eprom was found to be faulty (nvm)
Pressing the screen format button displays wide, smart, zoom and 4:3 modes but settings have no effect on picure
Enter TT35 in the service mode to select a 4:3 CRT
Nov 23, 2007 | Sanyo DS32920 32" TV
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
Vertical hold?
replaced this capacitors in vertical circuit.100 uf/50v,1uf/50v,1000 uf/25v,2.2uf/50v,47 uf/50v.this might not as exact as what is on ur tv.but, just replace those capacitors and see the result. hope this help u....
May 09, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
