Question about Canon PowerShot S2 IS Digital Camera
Display is white inside & out
When I open the display panel the display is white. No caption, no icons, no image. When I change to the viewfinder display, it is white, too. I've tried new batteries, different SD card, and a reset-to-defaults. What could it be?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Try hooking it up to your PC and using the REMOTE FEATURE, see if you can change the whiteness lvls from there or see anything on you pc, if you can then your lcd screen is shot and might need to be replaced or checked at your local service place.
Posted on Sep 18, 2007
  • scott gregg
    scott gregg Sep 18, 2007
    To get to remote Feature hook up your camera and open up the drive label camera or removable drive/hardware. It should be the feature all the way on the right.
SOURCE:
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
When I turn the camera on the lcd and viewfinder only display setting icons the rest is black. The lense does extend. Display and viewfinder work in view mode. Whats the problem? Is it worth repairing? Is...
Hi there, Here is something to try:
1. Set the camera toTV mode
2. Set the shutter to 15 sec
3. Click to take a photo/image/video like you normally do.
4. During the 15 seconds _a about hal way into it 7-8 seconds) open the battery door/cover
5. Insert the batteries again and close the camera battery door.
See if it works?
Hopefully it does. I hope this helps you out!
Feb 13, 2011 | Canon PowerShot S2 IS Digital Camera
Friends are reporting a display image in messenger that I am not seeing. How do I delete it when I can't even see it?
To change your display image on yahoo messenger follow these steps:
Login to your messenger,
At the top left corner is an icon which looks like a face directly under the messenger tab of the messenger,
Click on the face icon,
An extension comes out with manage display image,
click on display image and decide if you want to share an image or not as well as change whatever display image shows there.
Hope this is helpful
Jul 08, 2010 | Yahoo Messenger
Fuji S6000fd; black display, both lcd and viewfinder
I have the same problem except everything is white, not black.
Jul 05, 2009 | Fuji FinePix S6000fd Digital Camera
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
AQUOS 42D43U - Display clipped when used aas monitor
yes how are u runing video card to tv ? compunt cable cant do that need to u se dvi plugs or 15 pin blue to it to see whole picture just cant shoot screen out compunt for video only files ok
Mar 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony DVD92 LCD/Viewfinder doesn't display image
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Dec 17, 2007 | Video Cameras
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Sep 29, 2007 | Canon PowerShot S3 IS Digital Camera
Malfunction?
If the LCD display is open, the viewfinder becomes inactive. Shut the LCD display, and the image should appear through the viewfinder. If there is still no image, the camcorder may require service.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon PowerShot S2 IS Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
