Question about Acer Aspire 5520-5156 Laptop
I need the system recovery cd rom sent to my e-mail add.
I'm having problems connecting to the internet.
Risk of losing data by re-booting CD-ROM recovery disk
Copy off your data to another computer before recovering. A recovery usually restores to factory settings and loses all data.
You could boot to Ubuntu or Linux and copy your stuff that way, then when restored, copy it back.
Feb 11, 2016 | IBM ThinkPad Computers & Internet
Sound driver unistall and how to restore sound driver
Go to Control panel > Add Remove programs (locate the audio driver installation) > click Uninstall (Remove).
The presently installed audio driver will be removed from the system.
Reboot the System
Right-Click 'My Computer' icon.
Click 'Properties'.
Click 'Device Manager'
Click on 'Sound and Game controllers'
Right click 'Audio device'
Select 'Update Driver'
That's all. The audio driver will be re-installed. If you have the Driver CD of the audio card, just put it into CD driver, before doing this. If you have internet connection, connect it too. If so, the system will audo-search for the audio device, and will install it automatically either from the O/S, CD Rom or by internet. [Before doing all of this, connect the system to internet, Insert the Audio Driver CD in the CD Rom (if you have it]
Gopakumar Gopalan Google
Apr 16, 2014 | Computers & Internet
How to install CANON LBP2900B PRINTER SOFTWARES IN MY SYSTEM, WHICH HAS NO CD DRIVE AND INTERNET CONNECTION
Hi there! Without the access to the internet or a CD Rom, there is no way to add the drivers to your system. BUY, do you have a USB port??
Jan 27, 2014 | Office Equipment & Supplies
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
I need as restore cd for my emachines e725 laptop. I can not talk to anyone at emachine.com
In the past, I have telephoned eMachines and have ordered (about $20) a replacement "System Recovery" set of CD-ROMs for my eMachine computer. Add another $20 for overnight-courier.
Jul 19, 2011 | Computers & Internet
I have a a45-s130 toshiba laptop computer....My system recovery rom won't work...I know that the rom is the correct one because it was sent by toshiba...Everytime I start the computer with it in the rom...
This happens quite a bit. The recovery CD is looking for a machine ID from your laptop and didn't find the correct one. You need to download Toshiba's DMI utility (put it on a CD and make it bootable), boot from it, then run DMI Utility and tell your machine it is an A45 series. That'll do it.
Oct 25, 2010 | Toshiba Satellite A45-S130 Notebook
Is there a website where i can download a recovery hp pavilion zv5000 disk
If you have a Windows Xp CD and your laptop has the serial no. then
1. Insert the CD in CD-Rom and follow the instruction to install the Windows XP.
2. Once you installed the XP, try to get connect with internet, most of the time the LAN drivers installed, plug the Ethernet wire with your computer go to the browser.
3. type www.hp.com
4. Click Support & Drivers
5. Select Download Drivers and type your product no.
6. Install each component Sound, VGA, Wireless from the list.
This is the simple way to recover your computer without recovery CD. for this you dont have to be technical but smart to choose the steps. Good Luck. Amir
Jun 19, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
No bootable device
I think you must reload the operating system and buy yourself a GOOD virus/malware protection software. If you do not have the recovery disc set contact the customer service number for your computer manufacturer to buy the set. Here is a link to the Dell support website. Support Dell US
May 01, 2017 | Dell Inspiron 8200 Latitude C840 Laptop...
I got a cyberpower pc need help
Are you using windows XP or Vista. You should not have a problem if after you do a full system recovery, you add any service pack updates. Download these first and burn to a disk. Also make sure that all the drivers get reinstalled ok. After doing the recovery go into system device manager to see if your network card is installed even if it is a internal one on your motherboard.
If your connection is wireless you may need to setup a wired connection first from the router.
Time warner roadrunner usually works right away with little problems.
Jun 21, 2008 | Computers & Internet
Recovery disk
I have recovery CD's for presario 700 series, works for most Compaq laptops and desktops, I can E-mail them to you or if you give me contact info I'll mail them to you.
through e-mail they are sent as an image file and will have to be Burned on cd by cdrw and burning software. So if you prefer the easiest is to just load the cd's i would mail you.
contact info
mewms_14904@verizon.net
Dec 29, 2007 | HP 285527-001 - Compaq Presario...
Acer Aspire 5520-5156 Laptop Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
