Question about Maxtor Hard Drive
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
I have an old maxtor hard drive 40 gig, and i have an old pc with an asus board P4VP-MX ,but the moment i inserted the hard disk to IDE it creates a buzzing sound when i try to boot my PC, but when i put the hard drive as slave my PC couldn't recognize the hard disk and it said it is not supported, how can i fix this problem? please help me. you can send me the details at my e mail, azs132004@yahoo.com. thanks and looking forward for the help. jigz
  • azs132004 Apr 20, 2009
    I have already tried that twice but still it doesn't work either, or maybe is there any solution to this aside the jumper setting?
Just need to set the jumper so this will work as the slave
Posted on Apr 20, 2009
Pc does not recognize slave drive
Look into the computer bios / setup and see if the drive is detected there.
to get into the bios or setup press the button indicated on the screen right when you turn the computer on, it can be either F1 F2, f10, del, space, esc depends. it should say on the screen.
May 21, 2009 | Maxtor Hard Drive
Adding a hard drive to a PC
You need to set the little jumpers at the rear of the hard drive and the cd rom drive. Set the hard drive as Master and the cd rom as Slave. Both devices should then be recognized.
Dec 30, 2008 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
Brand new Seagate Maxtor OneTouch 4 plus 750 Gb isn't recognized
jumpered wrong or its a fake drive (knockoff) but doubtful so the real diagnostics is
start run diskmgmt.msc in it you will find if drive is unalocated or not even detected. if its not detected goto run type eventvwr and check in system for errors ..
im starting to think upper and lower cdrom filters are causing usb issue. i had issues with old zip drive software causing this.
Aug 01, 2008 | Maxtor Hard Drive
No longer recognized by Win Me PC
UNINSTALL THE HARD WARE FROM THE SYSTEM ..UTILITIES FOLDER IN CONTROL PANEL
IF ITS RECOGNISED THERE IT MEANS THE DRIVE NEEDS THE SAME WIN ME DRIVERS WHICH COULD BE CORRUPT
YOU CAN TRY TO CONFIG IN SETUP TOO.
CONFIGURE THE HD IN HARD DISK DETECTION NOT AS AUTOMATIC IN BIOS , BUT AS LBA MODE DEFINING THE CYLINDERS AND THE HEADS AND OTHER DATA WHICH IS USUALLY WRITTEN ON THE HD WHITE COVER.
May 04, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
I have a maxtor 40 gig hard drive IDE. Do you know the pin position to make this hard drive the slave
well..more information on your computer would be helpful. can you supply that?
Apr 30, 2008 | Computers & Internet
I have 6 Maxtor drives, from 1 30 gig, i 40 gig, 120 gig, and 3 80 gigs. Recently I have had failures on 3 of these drives. One minute they are fully functional and the next day they won;t boot and the...
the hard drives will have a date stamped on them if they are within their three year warranty period you should contact the hd manufacturer and see if they will refurbish it for you .
Apr 28, 2008 | Computers & Internet
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Hard drive instalation
To slave the Maxtor you remove the jumper or jumpers
Oct 30, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
205 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
