Question about Acer Aspire T180 PC Desktop
Upgrade memory from 1g to 3g
I have an acer T180 I am have installed the addtional 2gb so I have 1g and .5g in each of the dual slots but it keeps crashing on boot up and will only run in safe mode. I have done full memory test but it show no problems. Can anyone help?
  • 1 more comment
  • mrninja
    mrninja May 11, 2010
    All RAM sticks must be installed in pairs of the same type and size stick
  • Leng Yang May 11, 2010
    Also, double check that your RAM sticks are seated completely into the slots with the locking pins securely in place on each end. (It takes a good amount of force to click in RAM sticks)
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    Is your newly installed memory
    Memory Standard
    DDR2-800/PC2-6400
  • 24 Answers
Are the memory stick the same speed as in ddr2 800mhz also check the specs of the motherboad make sure you have not done too much ram or too juch speed
Posted on Apr 18, 2009
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
I insert 2GB pro memory stick card into the approprioate slot; auto play does not run, computer does not read card; none of the removable dsk drives recognize the memory card. It used to work with1Gb...
hi you dont say if the card is a sdhc 2gb or standard card .If its a sdhc card then you acer t180 does not have the proper drives for sdhc cards,and acer dont supply an update.
Aug 23, 2010 | Acer Aspire™ T180 PC Desktop
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
How i can upgrade the memory for AST180-UD400B ATHLON 64 X2 4200 up to 4gb also how many per slot.
you need to check how many slots it having.. in each slot you can put maximum 2GB memory..means if its having 2 slots , you can upgrade upto 4GB ,
Apr 01, 2010 | Acer Aspire™ T180 PC Desktop
Does Acer Aspire T180 support Windows 7?
i have an acer t180 which has 1gb ram and amd athlon 64x2 processon which gives me 2.01 ghz speed, i'v installed windows 7 ultimate converting from xp and everything seems to be running fine, there are netbooks etc which have low ram and processor speed but they still are sold by big companies with windows 7 installed
Feb 20, 2010 | Acer Aspire™ T180 PC Desktop
Memory Upgrade
I believe the max you can go with per slot is 1gb.
This is copied from the Acer site:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM
http://www.memoryx.net/acerxtd1024.html
Jan 31, 2009 | Acer Aspire™ T180 PC Desktop
Aspire t180 memory problem
check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Oct 17, 2008 | Acer Aspire™ T180 PC Desktop
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 PC Desktop Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
