Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My bissell deep clean carpet shampoo machine does not spray,
It worked d fine, then stoped spraying the solution empties out of the bottle but doesnot spray, the carpet gets damp but not wet. the red bar on the bladder also keeps raising. i shut it down, turn it on and the bar will raise in a few minutes.
  • Anonymous Apr 24, 2009
    The machine will not **** up the water
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yfggf
Posted on Sep 30, 2010
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No water or solution spraying
Used an air compressor to clean out the clogged tubes
Jul 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shampooer tank not working
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
Nov 10, 2007 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
458 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
