Question about HP Deskjet 2360 InkJet Printer
Printer has connected but offline.
Printer and computer has connected when print the printer showing offline message.
    Problem Solver:
  • 11 Answers
Your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
Posted on May 01, 2009
  • JOSPHAT NJOROGE Aug 08, 2013
    there is proper conection and the usb cable is okey.but my computers cant read the printer
  • 69 Answers
Correct install your printer driver software
Posted on Apr 18, 2009
3 Suggested Answers
  • 320 Answers
SOURCE: My printer is showing offline. I have unplugged
Try to right click your printer's icon. Check if the printer is set as the default printer or check if the printer is set to function online. It will not print if it was set to function offline.
Posted on Nov 22, 2010
SOURCE: want to print a chart but computer says hp
Pls. go to this page and select the type of operating system that you use for STEP by STEP procedure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02221706&cc=us&lc=en&dlc=en&product=3737195&tmp_track_link=ot_search#N73
Posted on Mar 06, 2011
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Why does all-in-one printer Canon MP495 keep showing up as 'offline' when all connections and cables are secure and PC can see printer?
canon mp495 printer offline error.pdf - WordPress.com
https://tumulcozi.files.wordpress.com/.../canon-mp495-printer-offline-err...
the printer model to remove and select 'MP If an error message appears or if you ...computer keeps saying mu wireless canon printer is off line If you feel any of ...
Jul 26, 2015 | Canon PIXMA MP495 InkJet Printer
My printer says offline and won't print
Is your printer turned on?
Connected to the computer?
Showing an error message on the printer?
Typically, your computer will set a printer offline when it can't talk to it, so we do the above testing first...
If your printer is indeed on, and it's connected to the computer, there are things to try:
change connection wire.
change which port it's connected to on the computer
test on another computer
Jun 09, 2015 | Office Equipment & Supplies
I have A Canon MX410 printer and is showing message offline and I have unplugged and plugged the printer. I have a Mac Mini and it worked fine for awhile. What to do??? Thanks Rick
Is the Pixma connected to a wireless router (or connected by USB or ethernet cable)? It could be that the router connection failed. Try restarting the router, or repeat wireless connection on the Pixma.
Feb 04, 2018 | Canon Pixma MX410 All-In-One Printer
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi i have a epson workforce 620 printer. but my computer says it's offline? my computer is connected via wifi all the other computers on the same network have NO trouble printing via the wireless but...
The Epson printer connected to your system requires drivers to function properly. Drivers link the Operating System and the printer, and issues with the drivers would directly affect the functioning of the printers. If the driver is not able to communicate with the printer, the Epson printer would show an offline message. All users having this problem are advised to check the printer drivers installed on the system using the device manager and if the drivers are found at fault, they would have to be replaced with suitable ones
Get more information to fix Epson Printer Offline Error . Hope this information helps you.
Jul 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Dell 3100cn Printer
Hi Lillie,
No, the message for RAM disk has nothing to do with your issue. RAM disk is an option for that printer, but most users do not have that option, and if you accessed the menu for the 3100 on most of the machines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not mean that your computer is communicating with the printer. In Fact, that message would show up even if you did not have it attached to any computer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the "reports" menu. Select either the printer settings, or the PCL Fonts report. When selected, the printer should print which ever report you selected.
One thing you may want to check is to see if there are any print jobs " locked up " in the print spooler on your computer, and also make sure that the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job that had a problem and is "stuck". This will prevent any job sent after that to be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clicking on "printer" from the menu and ensure that work offline is not checked.
Good luck.
Oct 06, 2008 | Dell 3100cn Laser Printer
OFFLINE problem - unable to print
if your printers saying Offline, it means that your printer is not connected/switched on or detected by the computer.
Try a hard reset or re-installation of the printer itself.
power on/off ( On the printer )while this error message appears.
Check the cable from Printer To Computer.
Mike @ Compurepair.
Feb 23, 2008 | Computers & Internet
HP Deskjet 2360 InkJet Printer Logo
187 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
