Question about Sony PlayStation 2 (PS2) Console
Drawer wont open or close
Somtimes the disc draw will not open or close unless you help it along. I sthere a way to realign the gear so that it will operate properly.
    Scholar:
  • 57 Answers
Loke Sounds as tho just retracking it will help but something has caused this and it may happen again, look around when its open and see if you notice anything out of place. anyhow heres a link to do a step by step for your repair. http://www.neoseeker.com/Articles/Hardware/Guides/ps2diy/
Posted on Sep 18, 2007
  • 4 Answers
Your ps2 drives moter must have been having starting problem.
6ya staff
SOURCE:
Compact disc drawer on unit does not open
Drawer was jamed,It will have to be taken in to a repair shop, To be realigned, Unless the gears are jaming up, Then you might as well just look for a different one, You could take the cover off to see what it is doing,
Nov 04, 2012 | Denon Audio Players & Recorders
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
Hello
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
WISH YOU A HAPPY PROSPEROUS 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | Televison & Video
Disc tray does not come out, display say hello
There is a flex cable that attaches the tray assy to the main pcb ,make sure that has not pulled out, also see if tray tries to move at all as it may need the mechism realigned and the open/close switches cleaned.Also the is a gear that turns the tray that has broken teeth on,check that gear ,as tray must turn before unit will intalize
Apr 16, 2010 | Kenwood DV-605 Multi-disc DVD Player
Disc table does not open or close - stuck open
Hello the unit is out of timing now, it will have to be taken apart and retimed. You have skipped some gear tracks and the unit will not close until the Tray is realigned. Try hitting the eject button so the tray comes all the way out then pull on it gently to see if it realigns it self. When it trys to go back in it is hitting the clamper because the tray has not reached home and the clamper that gasps the disk is closing before it has a chance to return home.
Nov 30, 2009 | Pioneer BDP-95FD Blu-Ray Player
Computer disc drive door will not close and the computer is on
Try this: Computer is off and feed tray is open.
Try to play the feed tray, pull it out gently fully and observed if it is smooth. You should feel the gear. Then push it back gently but not close it to its bezel. Then repeat process four times. Then push it fully to close. This method tries to reseat it gear and locks inside. Then power on. It should closed upon powering the unit.
If you don't feel the gears it could be the motor belt connecting the driving motor and the gear is detached or been broken.
It could be also the loading mechanism is stuck.
When this happens replace or disassemble the unit and realigned it gears or loading mechanism. The second I don't recommend it coz of the laser part inside.
Mar 28, 2009 | Dell Microsoft Windows XP Home Edition
The door would not open so got paper clip and opened now won't
Philips cdr600
Needs a new laser or realigning service using philip's COMPair diagnostic system.
Oct 13, 2007 | Philips CDR600 CD Recorder
Disc changer won't open
sometimes the timing cam that is just below the tray, it is a plastic bar with teeth along its edge will get out of sync with the tray, draw it to the opossite end and put the player back together and the players tray assembly will re sync itself...i hope this helps you
Jul 30, 2007 | Samsung HTQ45 System
The tray doesn't close anymore. Keeps turning.
Very specific alignment procedures.Tray must be removed along with front panel.Gears must be reset for proper timing.This is not a simple fix unless you know proper procedures and timing points.Best to have it serviced.
Apr 14, 2007 | Panasonic SC-HT740 System
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Sony PlayStation 2 (PS2) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
