Question about E-Machines eMachines Desktop PC
Restore and install
Ok im a dummy! i forgot my administrative password for my computer what can i do to figure that out i want to install a new program for my computer and i have no idea what i need to do! HELP!!!!!
  • 1,006 Answers
Re: restore and install
Download this program and burn in to CD and start pc from cd it is wery easy to remove admin password with this program
Posted on Dec 21, 2007
  • 98 Answers
Assuming that the machine is running Windows 2000 or XP and has a floppy drive, it is possible to obtaina set of floppy discs which, when booted, will enable you to reset the admin password. There are two flavours: an Open Source (free) version which works perfectly but is not so user friendly as the commercial solution which is easier but costs. There are quite a few solutions out there. A google of "windows XP password reset" will find what you probably need.
Posted on Sep 17, 2007
0 characters
3 Points
How to Reset Forgotten Password on Computer
How to find computer password quickly that I forgot computer password? Can anyone help me reset forgotten computer password? Any helps will be appreciated! - Now check the following ways on reset lost computer password!
Firstly, use password prompt function on password locked computer
If you have set the prompt option when you set account password, it may help you remember something about your forgotten computer password!
Secondly, reset computer password with default administrator account Once we install Windows OS, there will be automatically generated an "Administrator" account with blank password. Therefore, if we forgot password on computer, we can have a try:
a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
c. Recover computer password by: Control Panel - User Accounts.
Thirdly, find computer password with computer password reset disk If we created this computer password reset disk before we forgot password, we can opt for the disk to help us unlock password efficiently.
a. Click OK and close the message box on the password incorrect prompt window.
b. Click "Reset Windows Password" and insert the password reset disk.
c. Do as the "Password Reset Wizard" to create a new password.
Fourthly, change computer password with Windows Installation Disc Take computer Windows XP as example:
a. Start computer using Windows XP Setup CD.
b. When it asks to repair our current Windows installation, choose "Accept" it and press "R" to run the repair. Then computer will begin to repair our Windows and copy files to hard drive.
c. Setup will reboot system. Please don't press any key when there is "Press any key to continue..."
d. Now computer will do other tasks and there will be a progress bar displayed. Please notice carefully the details shown at the bottom of screen.
e. Once "Installing Devices" comes up, press keys: Shift+F10. Input: nusrmgr.cpl and press Enter key at the Command Prompt window.
f. The same "User Accounts" window will display as it is in Control Panel. Choose "Administrator account" and select any account listed to change or remove your computer password.
Fifth, break computer password by DIY a password recovery disk If the above four methods still can't help us reset lost computer password, we can refer to this way now. DIY a password reset disk after forgotten computer password means that we burn an .iso image file from Windows password recovery software into a bootable CD/DVD/USB disk. Now, take one of the top-rated Ainorsoft Windows Password Recovery Corporation as example:
a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
b. Burn an ISO image file to CD/DVD/USB Flash Drive
c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
d. Reset forgotten computer password to default Re123456.
The above ways on forgotten computer password reset are the collections of best bet for us to unlock lost computer password! So even if we forgot computer password, things will be OK soon!
on Jul 27, 2011 | PC Desktops
Forgot password no resset disk
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like
Oct 04, 2012 | eMachines PC Desktops
Windows Password Buster can reset forgotten Windows password.
Aug 03, 2011 | PC Desktops
Asking for password before system. Boots
Maybe you forgot the pass or some users put pass on your system or account..You can salvage your old user account by logging on as the "Administrator" user. Once you're logged in as the admin, you can reset your old user password. The Administrator user (by default) is similar to a "superuser" and has the highest access level to reset any user password.
If you don't know what your Administrator password is, you can reset that by rebooting into Safe Mode.
The best option here is to reset your account password. You can do this using either 1 of the 2 methods suggested by Microsoft Knowledge Base article #321305. In my opinion, the second method described on this page is most likely the easiest route: Reboot Windows in Safe Mode. Click Start, and then click Run. In the Open box, type the following command, and then click OK: control userpasswords2 Click the user account that you forgot the password for, and then click Reset Password. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Side note: To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
You can reset a lost or "forgot Windows password" with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like "Windows Password Breaker".
4. Re-install. Will lose data.
goodluck and hope this helps.pls rate ..thanks
Feb 21, 2011 | Intel PC Desktops
Forgot password and unable to do anything now
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0(
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Apr 17, 2009 | PC Desktops
I havent been able to use my laptop for 11 months because my charger cord was broken. now that i have the cord, im locked out because i forgot my password.
To log on to a computer as the administrator to reset a password, when that computer is in a workgroup of more than one member, follow these steps:
  1. Log on as an administrator.
    1. Restart the computer, and then press the F8 key during startup until the Windows Advanced Options menu appears.
    2. On the Windows Advanced Options menu, use the arrow keys to select Safe Mode, and then press ENTER.
    3. Select Microsoft Windows XP edition, and then press ENTER.
      Note In this step, edition represents the correct Windows edition.
    4. On the To begin, click your user name screen, click Administrator, and then type the administrator password.
    5. Press ENTER, and then click Yes.
  2. Reset the password.
    1. Click Start and then click Run.
    2. Type control userpasswords2, and then click OK.
    3. Click the name of the user account that you want to reset the password for.
    4. Click Change the Password, and then type a new password.
      Note If you do not want to use a password, click Remove password, and then continue to step "e."
    5. Click Change Password.
    6. Restart the computer, and then try to log on to Windows XP again
Dec 18, 2008 | PC Desktops
Forgot password
The first thing you can try to do is login via the main Administrator account....usually there is not a password set on this account and it will allow you to remove the password on the account you forgot the password to.....follow these steps
Using The Admin account:
  1. Shut down the computer
  2. Start the computer
  3. As soon as the computer powers on tap the F8 key on the keyboard
  4. You will see a black screen with white lettering and a bunch of options , selct the top option which says "Safe Mode"
  5. Windows will load (and everything will look huge on the screen but that is ok!). When you get to the "Welcome!" screen you should see the administrator on it to log in
Now you should be in Windows , to remove your password on the account you forgot:
  1. Click the "Start" button
  2. Click "Control Panel"
  3. Double Click on the "User Accounts" Icon
  4. Click on the account you want to remove the password from
  5. Click the link that says "Remove Password"
  6. Hit "Save"
  7. Restart the computer
Now you should be able to log directly into your account with no password. Once in the accoun tyou can follow the steps above to set a new password , instead of removing password @ step 5, click "Set New Password"
Oct 01, 2008 | PC Desktops
Forgot the log on password. need to recover the password or bypass to log on
here is one way for Windows XP
first, you have to log on as the administrator
Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account.
In the Password box, type the administrator password, and then click OK.
If the administrator password is set to a blank password, do not type a password before you click OK.
Then you have to RESET the password
Click Start, click Run, type control userpasswords2, and then click OK.
Click the name of the user account that you want to reset the password for, and then click Reset Password.
Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK.
Restart the computer, and then try to log on to Windows XP again.
Jul 14, 2008 | PC Desktops
Administrator mode
OK ..Click start and then "log off" when computer prompted you to type username;
username: administrator
Password: ___________, leave in blank
but if the computer just only need the password on the user, you should simultaneously Press " Ctrl+ALt+ DElete" do this successive two times( 2x)
prompted you like this; then type,
and then enter..
any problem arising this solution please tell me.
best regards, melnavz
Feb 21, 2008 | Acer Aspire™ T180 PC Desktop
E-Machines eMachines Desktop PC Logo
152 people viewed this question
Top E-Machines PC Desktops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you an E-Machines PC Desktop Expert? Answer questions, earn points and help others
