I have 845gv motherboard with agp slot 8x but as i try to install Nvida geforce fx5500 256mb card system boot but hangs at some interval of time
  • mrninja
    mrninja May 11, 2010
    I hope you installed it with the power off and took the proper ESD precautions, make sure the card is seated properly, the check the bios
    Problem Solver:
  • 5 Answers
Plese install the proper driver for your Nvida and disable any on board vedio port.
Posted on Jul 28, 2009
I have asrock p4i45gv r5.0 motherboard and want to ask if it supports ati raedon 6850 graphics card or not?
The AsRock P4I45GV revision 5.0 motherboard uses an Intel 845GV motherboard chipset.
There is one AGP slot on the motherboard, used for a graphics card.
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
2) Information on the Intel 845GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Looking down the column on the left side until we come to - 845GV, and looking across, we see under the heading Graphics that Integrated Graphics is supported. No mention of AGP support.
But AsRock has implemented it's own technology of A.G.I. at an 8x speed.
(For the Intel 845GV chipset)
A.G.I.
AsRock Graphic Interface,
http://www.asrockamerica.com/AGI8x.htm
This means that graphics cards that use the AGP 8X technology, or AGP 4X technology, can be used. (AGP4X/8X)
Advanced Graphics Port,
http://en.wikipedia.org/wiki/AGP
Using Sapphire's version of the ATI Radeon 6850 as an example, we can see this graphics card uses the newer technology - PCI-Express
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
(Doesn't natter WHO makes it, the graphics card is still based on the ATI G.P.U.
Graphics Processing Unit. Or in slang terminology; the graphics chipset)
It also uses the newest version of PCI-Express, the PCI-Express 3.0 technology.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI_Express
Short answer to your question?
No
Your AsRock motherboard is set up to support AGP graphics cards that use either the AGP 4X technology, or AGP 8X technology.
Does not support graphics cards based on the PCI-Express technology.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2011 | Asrock P4I45GV R5 Motherboard
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
Cant log on xp.
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
May 11, 2009 | NVIDIA GeForce 5500 / 128MB DDR / AGP 8x /...
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Dec 30, 2008 | Nvidia GeForce 6600 256MB 8X AGP Video...
HAVE A 6200ALE256DDR2 ON 845GV/GL. WILL NVIDIA 8XXX SERIES WORK?
what slots u have on motherboard if u have u can look it in here http://www.nvidia.com/page/geforce8.html mostly they use pci express slot
Dec 26, 2008 | XFX PVT44AWAH GeForce 6200 AGP 8X DDR...
Video Card not working.
Connect your monitor card into your origional monitor port. Boot to BIOS and disable the VGA port. Save and exit. After re-start, shut down and install the new AGP.
Dec 02, 2008 | XFX PVT44AWAH GeForce 6200 AGP 8X DDR...
Nvida geforce fx5500 256 agp compatible with intel d865gbf ?
Yes, they should be compatible. The Intel d865gbf has an AGP port that supports AGP 4x/8x, and so does the FX5500. You should be fine.
Nov 05, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Nvidia Geforce FX5200 128mb DDR AGP 8x
Hi, since you mentioned you installed an MSI card & it worked well. I can assume you changed the bios & to boot to the AGP rather than the Integrated 3D video. This is good. Notice the message you got from Nvivia. It could not locate any compatible drivers. This can indacates 1 of 4 reasons.
1. The 5200 was not completely incerted into the AGP slot.
2. The AGP slot is dirty & needs cleaned.
3. Nvidia software was installed but previouse graphics software was not removed (un-installed) before the installation of the nvidia software.
4.The card is bad.
Suggest you download the latest driver software from Nvidia.
Jun 17, 2008 | EliteGroup L7VMM2 Motherboard
Compatible video cards
This motherboard has an 8x AGP slot. So any 8X AGP graphic cards will suit this mobo. As your local reseller for any 8x AGP based graphic cards from ATI or Nvidia.
Dec 26, 2007 | ASUS P4V8X-MX Motherboard
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
