Question about Sharp VC-A410U VCR
Channel four not three
I cannot find the way to put the vcr to play on Channel 4 - the Channel 3 works but the tv itslef, on that channel doesn't receive well that channel - so even the vcr plays poorly. I have a cd player hooked up and it plays well on Channel 4. I do not have the manual and have searched the web trying to find a written solution. Thanks
  • berrigano Sep 17, 2007
    The vcr is a Sharp VC _ H961
    Problem Solver:
  • 13 Answers
In most cases it is just a matter of flipping a switch on the back of the VCR. If therre is not a switch there, then the only solution I can find would be to find an owners manual somewhere. You might try searching the manufacturers website for an archive of owners manuals.
Posted on May 11, 2009
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
The VCR is playing and functioning, but the picture won't show up on the TV. I have all the channels set and it should be working, but the TV is the black and white static. Could it need dusted? It hasn't...
make sure the tv vcr button on the vcr is selected to vcr and that you have the tv on channel 3 or 4. try pushing the tv vcr button a few times back and forth on channel 3 then on 4. if that doesnt work try hooking the vcr up to the tv with the rca jacks. they will be yellow, white and red or maybe only two from the vcr yellow and white. hook them up the the correct input on the tv and change the input on the tv. if that doesnt work, your vcr may be done.
Dec 24, 2010 | RCA VR557 VHS VCR
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
WHY DO I HAVE TO PUT MY TV ON CHANNEL THREE TO WHATCH A MOVIE
Both previous solutions are correct, but there may be another step. Sometimes the switches are hard to see because they are small and hide near the antenna in and out jacks. But some newer VCR's don't have a selector switch at all. To choose between channel 3 and channel 4 output, you need to use the VCR's setup menu. So if you can't find a switch like the other posters mentioned, check the VCR setup menu for an output channel selection. Then, as previously mentioned, make sure that the VCR output channel is added to your TV's channel lineup.
If you find a solution not exactly what you need, or not clear enough, please post a followup before giving negative ratings (thanks for trying or not appropriate). While those of us who take time to answer questions and try to help here don't get paid, we are more likely to be taken seriously if our ratings stay up. At the very least, both of the previous solutions should have been ranked helpful, because they are correct and should have given you the advice you needed.
Oh, one last thing: In posting, using all capital letters makes it hard to read, and is the equivalent of shouting. Please turn off the caps lock key. Thanks!
Mar 05, 2009 | Daewoo DTQ-20N3FC 20" TV
I am trying to copy from the tv to the vcr, how do I do that?
Put the VCR on the channel you want to record not the TV!
Jan 19, 2009 | Televison & Video
Magnavox 2205 DVD/VCR Output Channel Control
1: set tv to channel you want your vcr output to be on. 2: turn vcr on (if it is a vcr/dvd combo make sure it is on vcr) 3: put in video tape. 4: press play button one time, release it, and then press and hold it for three to five seconds. i had to call customer support to figure this out on mine.
Jan 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd won't play
You may have to buy an RF modulator ($20.00 at any radio shack or wall-mart) this will allow the hook up to work! ( has a channel 3 or 4 selector switch!)
I hope this is of big help!
Please rate answer
Thank You!
Jan 16, 2009 | Samsung DVD-V4600 DVD Player/VCR
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Sharp VC-A410U VCR Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
