Question about Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher. The pump won't turn off - Asko 24 in. D3250 Built-in Dishwasher
  • watsonsa Apr 20, 2009
    Thanks. That's perfect. I removed the dishwasher and tilted it forward until all the water stopped running out. Once i did that it works fine again.
    thanks for your help
    Stuart
  • pgalbraith Aug 05, 2014
    Great! Fixed in under 5 minutes! Thanks so much!
  • 12 Answers
This could be the anti flood device has operated in the base of the machine. This is a polystyrene disc that is attatched to a microswitch. If there is water in the base of the machine this disc floats and turns on the pump
Posted on Apr 18, 2009
  • Vytas Juskys Jan 17, 2011
    I just fixed my dishwasher by unscrewing two screens on the inside at the top of the door. This enabled me to tilt the dishwasher forward. Next I unscrewed the filters at the bottom of the washer and used a wet vacuum to **** out all the water. When I pushed the washer back into place the pump turned off. Took 15 minutes.
A friend told me about this site and emailed me this page. After reading the cause of the problem, I set out to ensure it might be the problem before disconnecting and dragging the unit from under the counter. I figured that if it was water I'd put the handle of a wooden spoon down the drain in the machine and see if it got wet. There is a narrow filter to catch debri that easily removes for cleaning. In searching for a wooden spoon I found our garden variety turkey baster. I reasoned that if there was water there, I could syphon it out to prove it. I took about a cup or more of water out, reconnected the quick disconnect to return the power to the pump, pressed the power buttom and it worked fine. Ultimately, the entire fix for this should take about 10 seconds if you know what to do from the start. Go figure!
Posted on Jul 07, 2010
    Novelist:
  • 150 Answers
If there is water in the interior base of the unit causing the safety float to activate, the reason for the water should be addressed. Dishwasher detergent SHOULD NOT cause excess sudsing, there are anti sudsing agents in the detergents to help prevent this, they have a shelf life and will become less effective in their function. The blister packs coitaining detergents and rinse aids are not reccomended as they almost always create too much suds, and are mainly a marketing tact. We always reccomend simple Cascade powder, or Sun Lite liquid. So, over sudsing can cause water to accumulate in the base of the unit by leaking down the front corners, additionally these units are well known for the wash pump motor seals leaking after normal wear and tear filling the bottom with water. By removing the water from the base the safety switch is simply being reset and the unit thinks all is dry down below. PLeazer Appliance...
Posted on Jan 14, 2015
    Habit-Forming:
    New Friend:
  • 13 Answers
If your pump will not shut off then it’s probly because the unit has detected a leak in the bottom pan
Posted on Nov 26, 2017
    New Friend:
Hello everyone,
thanks to you that add the reason why the pump would not stop. After having dried the sump and restart the dishwasher it did the same. So there was a leak under. I decided to run the dishwasher while pulled out of the cabinet. For a reason I can't explain the black coating under the tub has melted, cracked and fell off in parts. The drain hose rubbed on the edge of the coating thickness and started to leak. So, I must replace the drain hose and it should be ok.
Hope that will help
Posted on Nov 25, 2017
    New Friend:
Thank you!!
Posted on Sep 18, 2017
    New Friend:
Thanks to you all, especially Lynn A. Shinmoto. That was very useful.
I had the same problem. I dried the pan underneath the dishwasher. But the problem still remains.
I disconnected the hose drain of the dishwasher from the pipe of sink drain. And then, a few debris got out of it. That solve my problem.
Posted on Jan 09, 2016
    New Friend:
I have success with the solutions above to resolve my drain pump issue. I tilted my unit forward and loads of water came out. Reinstalled it and it is working like new. Anyone know how often this needs to be done? Been in this house for 4.5 years and haven't had to do this until now.
    New Friend:
That was great info as I came home tonight tired only to see the pump not turning off, probably had been running all day. I think the pan flooded and tripped the float switch because the drain was blocked with a macadamia nut, just pulled it out drained the pan by tipping forward and it now seems to be working normally.
Posted on Nov 11, 2014
    New Friend:
You guys are sensational!!!!!
I booked Asko repair and it was going to cost $99 for call out fee + $35 for every 15mins.
Following your instructions I pulled the dishwasher out, tipped it forward until the water had drained out. Plugged it back in and presto...FIXED!!!!!!!!!!!!!
Thank you, thank you, thank you!!
Posted on Jul 02, 2013
Dishwasher is letting in water but the pump is no soaking in the water to wash the dishes
Posted on Jun 27, 2009
SOURCE: asko 3250 dishwasher pump not shutting off
I have had the problem of the water pump on my Asko Model D3121 running continuously several times. I contacted Asko customer service and they told me that the reason that this is happening could be that I am using too much dishwasher detergent. I was told to use a little less than 1 tablespoon for each load. The customer service person told me to actually measure it out. It is not very much. But, this doesn't fix the problem if it exists. To try to fix this, first turn off the circuit breaker for the machine or unplug the machine, whichever is easier. I was also told that there are 3 filters on the bottom part of the inside of the dishwasher. There is a grey basket that you squeeze the sides and remove. Underneath this grey basket, there is another basket that you unscrew and there is a wire mesh filter piece that the basket sits on. I was told to clean all of these filters with warm soapy water. Then, inside the hole underneath all of the filters, there is a yellow plug on the side. You pull this out (be sure to observe how the plug fits into the side of the hole since I didn't pay attention and it took me a long time to figure out it goes back in) and stick you finger inside the hole to see if there is any debris stuck in there. If there is, you should take it out. The reason the pump keeps running is because there is water in the pan underneath the dishwasher. It is really hard to get to the pan without removing the front lower panel and this is really hard to do. So, what I did was take some dishtowels and I stuck them into the hole that all of the filters fit into (I had removed all the filters and the yellow plug). I kept using dry towels as the others got wet. This sucked up a lot of the water. I then took a turkey baster and tried to angle it into the hole and try to **** up more water. Someone also said to use a syringe or maybe one of those kitchen syringes that you use to inject butter or flavoring into food. After I got as much water out as possible, I turned on the circuit for the dishwasher but the dishwasher pump was still running. I turned the circuit breaker back off and then I waited two days and whatever water was left must have evaporated. The pump stoppped running when I turned the circuit breaker back on. Once the pump stops running, YOU NEED TO CLOSE THE DOOR TO THE DISHWASHER AND HOLD THE START BUTTON IN FOR A FEW SECONDS. The machine will start making noise while you are holding the start button in but then there will be a "click" kind of noise and the dishwasher will turn off. This RESETS the machine. I didn't do this the first time and I ended up with the pump running again. Sorry the solution is so long but I wanted it to be detailed so maybe I could save someone the agony I went through. But it worked and I got to cancel the repair appointment which was going to cost a minimum of $185.
Also, I was told that every 3 to 6 months, I should clean out the filters and also put a bowl with 2 cups of lemon juice on the bottom basket of the dishwasher and run it without only the bowl in there. Customer service said that I could use vinegar but that the lemon juice smells better.
I hope this helps someone!
Posted on Nov 08, 2011
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do I remove the cerculation pump
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Posted on Apr 22, 2010
Testimonial: "Yhanks for the info now I need to decide new washer or fix rhis one any recomondations on a new one."
ginko
  • 19396 Answers
SOURCE: My Asko D3121 dishwasher won't turn on. When
Hi.
There is no error code, then check the following:
1)Check that the problem is not overflow.. Remove the lower access panels and check the tray under the dishwasher. If you find it is full of water use a cloth to dry water. Test the overfill switch.
2) Disconnect power, move the appliance forward and check that the drain and inlet hose is OK. Be sure that the machine is filling. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray.
3) Test the door lock. This can be tested jumping its contacts.
4) If all the rest is OK you may have a defective control module. This is not a common fault. Ensure that all the rest is OK first, wiring and pump motor must be tested before going for control module.
Start checking for overfill, that is a very common fault that may cause cycle not starting
If you want to contact a technician use the number listed on the USE AND CARE GUIDE.
Regards.
Ginko.
Posted on Apr 26, 2011
Asko advisory center
Try these... -Clean out the drain pump inside and below.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
make sure it is not clogged follow the line from under the sink and disonnect it from under the sink and make sure it is clear
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
Mar 07, 2018 | Asko D1776 Stainless Steel Built-in...
Asko 20.1 won't stop pumping unless I turn it off at the wall switch.
this happened to my D3111 and, sure enough, there was a split in the water outlet hose and the water overflow raised the polystyrene float block.
6 months later th same symptoms occurred but the inner base was dry. I took off the lower front panel under the door and found the water level (3 terminal) microswitch had burnt out, probably from running too long. Easy to replace if you can hunt down the $2 switch (brand name Zippy, 6 AMP)
Nov 16, 2012 | Dishwashers
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
D1976 machine won't do anything but pump out.
The flood switch must have tripped. This is likely to happen if there is a water leakage.
If you can pull the dishwasher out (after turning off the power and water connections) and tilt it on one side. Wait a little (to let the switch dry up) and then turn it on.
Hope this helps.
Jun 17, 2011 | Asko D1976 Built-in Dishwasher
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Apr 04, 2008 | Asko Dishwashers
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Asko 24 in. D3250 Built-in Dishwasher Logo
17,306 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
