Question about Brother MFC-440CN InkJet Printer
Paper jam the paper jam error won't go away and there is no paper jam
  • 2 more comments
  • Tai  Viinikka
    Tai Viinikka Nov 04, 2008
    It's quite frustrating.
  • Anonymous Dec 08, 2008
    get code 30 and 50 unit wo't turn off on switch
  • wsforchrist Feb 19, 2009
    i had a paper jam and cleared it now the code unable to print 30 will not go away and the machine will not turn off. i have tried all that you posted in your solution but i cannot figure how to remove the print head to see if there is any paper jammed there.
  • sanity_astra Apr 25, 2009
    yep, same problem here. I moved the printer head, put a piece of paper under it and tried moving it back and forth again.
    no luck.
We just spent ages with the same problem, the answer is actually on the link to the brother help pages - move the printer head. They just assume you know how. The printer head is the bit that slides back and forth when you put in a new ink cartridge. It sits over the left hand side when you lift the top cover. When we slid this to the right the offending piece of paper was hidden behind it.
Posted on Mar 11, 2009
Lift the cover of the usb/network place.
Posted on Oct 27, 2008
  • 832 Answers
See here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=us&lang=en&prod=mfc440cn_all&Cat=4
Posted on Sep 18, 2007
SOURCE:
Paper Jam Error
Epson RX595 Photo All-In-One Printer
Paper Jam Error
Dec 28, 2013 | Epson RX595 Photo All-In-One Printer
No paper jam but error 5110 won't go away
Have you tried unplugging the machine, this might reset it.
Mar 14, 2013 | Canon Pixma MP500 All-In-One InkJet...
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
There is still error 2 even after restart the printer (canon mp145). How to reset this error?
(remember to vote this solution plz)
I use a Canon MP210 myself, its a Pixma like yours. Anyways, Error 002 or 02 means theres a paper jam. Sro if you can fix that jam it will go away. If your looking at the printer and you cant see any jams still, the printer still thinks it is jammed, so heres what I would do.
  • Turn off the printer.
  • 3
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • 4
    Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • 5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • 6
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • 7
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • 8
    Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • 9
    If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Still? Take a cereal box of cardboard (cut the back/front , push that through the paper trayand get your hand on the other side and work it like your flossing your teeth)
    Yes that works.
    Thanks
    Rhos Barnes, MCSE, CCNA
    Squamish, BC
    [email protected]
    Jan 23, 2011 | Office Equipment & Supplies
    Error message is " paper
    Check for a tiny piece of paper or some toner that may be covering a sensor.
    Jan 07, 2011 | HP LaserJet P2055d Printer
    Carriage Jam problem. Have gone through complete troubleshooting routine, but the message just won't go away. Says ""Carriage Jam". No debris to left or right of carriage. In fact, the jam was in the paper...
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
    Oct 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Hi, I have a 200.00 paper jam in areas a and c. The paper jam has been removed but the error is still not going away. I have pulled out every thing that can be pull out and checked with no luck.
    check any dis alignment on the paper jam sensors..or check any posible broken wire on its harness that leads to the paper jam section..
    .....kenthbats
    Jun 07, 2010 | Lexmark C920 Led Printer
    Got a paperjam. Pulled out the paper, but the paper jam error won't go away and the printer won't print. I read that it may be the paper jam trigger spring that is out of place now and requires...
    No it's not. Make sure to open EVERY door on the printer and check for any additional paper. Also, power the printer off and back on a few times and see if it goes away.
    Dec 24, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
    How to erase a error message on Cannon mp 160 which says " paper jams" & it does not exit. and printer does not work.
    It should have a display showing you where the paper is jammed. Open that lid even though the paper is not really jammed and the error message should go away.
    If it fails, turn off and back on the multifunctional.
    Aug 24, 2009 | HP OfficeJet J4580 All-In-One Laser...
    Brother MFC-440CN InkJet Printer Logo
    176 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
    ctnozil
