Question about Toshiba Tecra 9100 Laptops
I Have one Laptop TECRA 9100, with LAN Mini PCI Card and I am traing to improve the Wireless-speed but I have only 11 Mbps, I like to know if is possible to change the Card for version ''g'' with 54 Mbps Atte Juan Carlos
Upgrade toshiba tecra 8200 lan mini pci card
There are all kinds of lan cards available, go to www.ebay.com Type: lan card, or pci lan card.
Apr 09, 2012 | Toshiba Tecra 8200 Notebook
What is WLAN 1591 Half Mini-Card?
1pcs Intel 5100 "Half" Mini PCI-E Wireless Card
Standard / Public Version fit in any brand laptop
Intel Mini PCI-E Wireless Card 512AN / 5100
  • Manufacturer: Intel Corporation
  • Manufacturer Website Address: www.intel.com
  • Product Model: 512AN_HMW
  • Product Name: 512AN_HMW WiFi Link
  • Marketing Information: The Intel WiFi Link 5100 Series is a family of IEEE 802.11a/b/g/Draft-N wireless network adapters that operate in both the 2.4 GHz and 5.0 GHz spectra. These adapters, available in both PCIe Mini Card and Half Mini Card form factor deliver up to 300 Mbps of receive bandwidth; in addition to providing a host of features that enhance today's mobile lifestyle.
  • Product Type: Wi-Fi Adapter
  • Wi-Fi Standard: IEEE 802.11n (draft), IEEE 802.11a/b/g
  • ISM Band: Yes
  • UNII Band: Yes
  • Number of Antennas: 2
  • Antenna Type: Diversity Antenna
  • Wireless Transmission Speed: 300 Mbps
  • Host Interface: Mini PCI Express
  • Dimensions: 1.06" Height x 1.18" Width x 0.13" Thickness
Jun 26, 2011 | ASUS A7V333-X (A7V333-X/L) Motherboard
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Is ddr upgrade to 1 gig for gateway mdw 500s? Is there a way that I can install a nic/ wireless card to pick up signals?
we need model number of the laptop please mdw 500s i cannot find listed. If its the same as the nx 500s then ddr 333 is required (200 pin sodimm modules)
for wireless they installed
Intel® PRO/Wireless IEEE 802.11b/g network card, Mini-PCI Pentium® M models only)
-OR-
Broadcom IEEE 802.11b/g network card, Mini-PCI (Celeron™ M models only)
  • FN+F2 keyboard combination toggles wireless networking
  • Antenna: Uses factory-installed internal antenna assembly
  • Operating channels: 11 selectable channels
  • Security: 128 and 64 bit WEP encryption
  • Operating Frequency: 2.4 GHz Direct Sequence Spread Spectrum
  • Maximum Data Rate:
    54 Mbps (IEEE802.11g)
    11 Mbps (IEEE802.11b)
I am not sure where you will find a mini PCi card to suit i would just use a slot in pcmcia card or usb adaptor
Jan 10, 2010 | Gateway Computers & Internet
Loss of speed with wireless
Wireless conection will only run as fast as your slowest device. i.e.
802.11 only supported a maximum network bandwidth of 2 Mbps.
802.11b supports bandwidth up to 11 Mbps.
802.11g supports bandwidth up to 54 Mbps.
802.11n connections should support data rates of over 100 Mbps.
So if you are running a mixed network with lets say a 802.11b wifi card on a laptop and a new laptop with 802.11n, your speed will only be that of the 802.11b card.
I hope that helps.
Jul 03, 2009 | Arris SURFboard SBG900 Wireless Router...
Toshiba techra 9100 laptop
Probably you must open the case, much work and hard the first time...
situated under the keyboard, usually and perhaps an antenn-wire to somewhere--
Apr 11, 2009 | Toshiba Tecra 9100 Notebook
Toshiba Tecra M2vS330- crashes when wireless card switched to "on
Hi, your problem does not have to see with the openoffice that download, It coincides with your card mini - pci wireless I damage, and is for it that whenever you ignite the wireless your Laptop restarts for hardware malfunction. the solution is to replace the mini wireless board.
Jan 09, 2009 | Toshiba Tecra M2V-S330 Notebook
Wireless error for tecra 9100
i have a full set of drivers for this machine but not sure how i cud send to you.
Jul 30, 2008 | Toshiba Tecra 9100 Notebook
Wireless LAN PCI card
for the tecra 9000 it does have a wireless switch on the side of the laptop or infront.
the only way to test this is by dismantling it and using a tester. (hope you have them).
Apr 11, 2008 | Toshiba Tecra 9000 Notebook
COMPAQ EVO N400C WIRELESS CONNECTION PROBLEM
Is the truemobile your using a PCMCIA card you slide into a slot or is it a Mini-PCI card that is inside the laptop?
Oct 22, 2007 | Compaq Evo Notebook N400c
Toshiba Tecra 9100 Laptops Logo
143 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
