Question about Microsoft Windows XP Professional
BLUE SCREEN ERROR CODE OxOOOOOO7E IN XP
BLUE SCREEN ERROR CODE OxOOOOOO7E IN XP PROFESSIONAL
  • 432 Answers
If you didn't yet then upgrade to SP2.
Update drivers for all hardware, in most cases this is a driver conflict.
If that didn't solve the problem then scan for viruses with AVG.
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?cdlPid=11006019
Scan for malware with Anti Malware.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?cdlPid=11004434
Scan for broken registry entires with Registry Mechanic.
http://www.download.com/Registry-Mechanic/3000-2094_4-10190447.html
Let all 3 software repair/remove the errs they find.
If the problem is still not solved then reseat the memory stick to another slot, since 7E with nt status code c0000005 (access violation) could be caused by faulty RAM. Clean the dust inside the PC.
If it still crashes, downclock the RAM.
If it does not resolve the problem, replace the RAM
I would use a bart pe disc or a linux live disc and back up your data first and then re install and install latest drivers, SP 2 etc and see if it does it again.
backing up your data and re install would be easier
Posted on Apr 18, 2009
Laptop shutting down on its own and said problem event name blue screen
The 'Blue screen error is a common Windows OS error.
You can find the reason of blue screen....read more
To solve this error in your laptop.see......Fix this problem
Aug 29, 2012 | Microsoft Windows XP Professional for PC
Compaq will not boot even in safe mode
change AHGI TO IDE ,
see boot configuratiob Hard Drive and any where you see AHCI or Sata
change it to IDE or alteration to other one
May 15, 2010 | Computers & Internet
Stop 0x000000f4(0x00000003,0x860A54CC,0x805C749A
What is the Stop Error code.. is it like 0x00000... depending on the kind of Error the resolution can be proceeded on.. it can be a software or a hardware issue.. so u need the error code.. to know the details of the error.. get the error code.. go to support.microsoft.com and type in the error code.. and u shall get all the answers on how to resolve the error.. let me know if u need more help :-P regards Guru
May 04, 2010 | Microsoft Windows XP Professional
Blue screen on dell svc tag:GSKTL1S.Ox000000ED,0x8734D9EO,0xC0000006 how to fix this error?
Fine..You have reached the Blue Screen of Death (BSoD)..common in Windows Operating Systems. Generally this must be a hardware problem. If parts liek RAM or bad sectors in Harddisk, such BSoD comes, indicating the crash of the OS. Try repairing XP using the cd. If not, go for a format so that the bad sectors in the Hard disk is repaired.
Thank you!
Sabharish
May 30, 2009 | Microsoft Windows XP Professional for PC
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
Blue Screen
Try disabling PCI-Express in BIOS setup
Feb 16, 2009 | ASUS Eee PC 1000H Laptop
Installation error
install windows xp sp3,
Nov 27, 2008 | Compaq Computers & Internet
BSOD in windows XP Professional
A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
Jun 26, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
630 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
