Question about Sony Cyber-shot DSC-W50 Digital Camera
Cannot take pictures...when the lens opens to take a pictures it tells me to turn camera on & off..
Sony DSC-W50 cannot take pics in any camera mode it tells me to turn camera on & off
  • samoangal Apr 23, 2009
    my sony digital camera 7.2megapixel has this same problem. when i turn it on. the lens keep open n close, and it does that for about 5 times, n at the same time it tells me that is access, after that the message comes on saying turn the power off and on again..but when i do that it does the same thing over and over. can someone please tell me what that means, n how will i fix the problem...thank you very much, n i appreciate it..
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Try the procedure in this tip.
Posted on Jun 05, 2012
jackboy
  • 2985 Answers
SOURCE: Sony DSC-P100 Lens Will Not Open - Dropped Camera
Motor mechanism is shot Sony customer support for advice My - bet? New Camera And treat this one with some TLC
Posted on Aug 14, 2007
SOURCE: Sony DSC W50 - lens stuck
im 11 and i just got a camera for x-mas and my lil sis dropped and it ddosent work so i tried a tip from here and it just mad eit worst
Posted on Jan 23, 2008
SOURCE: SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Posted on Aug 21, 2009
taran_2005
  • 10515 Answers
SOURCE: Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
  • 11967 Answers
SOURCE: our dsc-w50 has a stuck lens problem. will not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 08, 2009
Sony dsc-13
basically it is a Japanese Model from where u bought it
u are lucky u can get it free of charge replacement just tell me which region u belong there is a known issue of CCD failure u will get free of charge repairs for that from sony service centre in ur area and they will accept this info pls rate me FIXYA for this
see this it is translated from JAPanese to ENGlish
http://translate.google.com/translate?langpair=auto|en&u=http://support.d-imaging.sony.co.jp/www/cyber-shot/information/info/top_ccd_addition.html
Feb 21, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Sony cyber-shot dsc-w50
Sounds like you have two problems, both which mean bad news. The clicking could be a broken gear in the lens unit or off track lens.
The colors may be caused from a bad ccd or sensor internally.
Aug 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I dropped my Sony DSC-W50 camera with the photo shot mode
Some problem in the lens system.
Try to either push in the lens more, or pull on it, if the lens is out at all.
If it continues, sell it for parts, as is on a site such as Ebay.
Jul 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cybershot dsc-w50 records movies instead of pictures
I had the same problem with my camera.  I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures.  Go to Menu and scroll over to Mode, then select Normal.
Jul 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot DSC-W50 lens problen
thats normal.
it just doesn't have enough power to bring the lense back in.
once you charge your battery and turn it on the lense will automatically come back in and then out for you to take a picture.
Apr 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My Sony DSC-W50 just started taking dark blurry pics...
same here. had my camera about a year and a half when this started
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
Jan 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Replacement of lense in sony DSC 50
Hello!
you still wants this DSC-W50 Lens unit we can help you. For further information plz email me.
Regards,
Sharmila.
Nov 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
The lens mechanism is wrecked. I guess a repair will cost nearly as much as new camera- get your 'friend' to treat you.
Jul 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
