Question about Dell Dimension 8300 PC Desktop
Model No AL-096 Sahara memory daul channel
Ok, i added 1 gig ddr2 667mhz chip, but it only shows that it has 1 gig ram inside, is there some way i can change this?? os windows xp, i ran cpu z to check if the rams there, and theres 2 gig ram, so is there way to make the daul channel active???
  • 10 more comments
  • 20277962 Apr 18, 2009
    wel im not sure, its has 2 memory slots, any other reason why it would have 2 slots, but not able to run dual? motherboard model : ati -bonefish, any idees?
    ok, so why doesnt it pick up the other memory module?
    only 1 gig, but i have 2 gig ram modules in
    nope it doesn't recognize the ram, but if they are separately put in they both show up in the slots, board is pretty new, got the laptop last year, its a dual-core board, it has a max capability of 4 gig...
    ok, i put in both modules separately, in both slots separately, and it showed 1 gig, in bios, but when i put them together it does not change, any ideas?
    ok, module 1 and 2 is the manufacturer: transcend information, part number: jm667qsu-1g, module 2 is part number: jm488q643a-6, ok both are 667 mhz and both are ddr2, mother is the manufacturer: ati, model is bonefish 02, chipset :RS400, RC400, RC410, Southbridge 400, and chip is a t2250 chip... anything else?
    thanks, if the case its, that they are not compatible... then ill just buy another one, in the case of the bios, i think i should update my bios, dont know how, but you'll be there to help me :)
    its a laptop, dont have color ^^
    and ive just run a bios software program, to see if there is a problem, looks like its out of date, and i cant change anything in the bios setup, all i can change is the booting.
    cpu-z says:q3b51 and driver detective says:ati - 6040000
    phoenix notebios 4 release 6.1
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    Does your computer/motherboard support Dual Channel RAM?
  • 227 Answers
2 slots does NOT mean Dual Channel, that just allows for 2 RAM chips
Posted on Apr 18, 2009
  • 9 more comments
  • Arthur Hoffmann
    Arthur Hoffmann Apr 18, 2009
    Under System Properties in Windows, How much RAM is indicated
  • Arthur Hoffmann
    Well depending on how old your board is it may NOT handle 2 gigs
    Does your BIOS recognize the RAM? when it boots?
  • Arthur Hoffmann
    Well there may be a setting in the BIOS, (just to clarify) You put one Module in at a time and at booting the BIOS displays the correct amount of RAM for each single module?
    Did you try putting ONLY one into the second slot, without one in the first? this only works on some boards (some require bank 0 to have a module) but see if that works.
    I have some other ideas, depending on the result of the test
  • Arthur Hoffmann
    There are ONLY 2 solutions I can come up with, your RAM modules are NOT compatable with each other or you must tell the BIOS you have RAM in both SLOTS although you should NOT have to do that. Tell me the brand names and type and speed of each module. Also the Model or your MB You mentioned it was an ATI bonefish, but what is the model of the motherboard, it should be stamped on the board
  • Arthur Hoffmann
    let me research the info you provided, I will post my results (if any)
  • Arthur Hoffmann
    Well it will not be a case of a BIOS update but more so a change inside the existing BIOS, I have been using computers since windows 3.11, but actually only ran DOS programs, there was no internet and cell phones were a dream, I am not even sure there were many cordless house phone, but anyway, In all that time I have only upgraded the BIOS on 2 machines. It is not like a Software program upgrade, where the user sees or benefits from the New features. If it is working do not mess with it, the BIOS controls EVERYTHING including windows.
  • Arthur Hoffmann
    Well the RAM seems compatable, very few diferences between the two.... let me look into the MB, can you post your BIOS type and version.
  • Arthur Hoffmann
    Can you tell me which slots (color) you are putting the ram in?
  • Arthur Hoffmann
    OK, sorry was looking at the RS400, not the RC410
    also here is something interesting about your board
    • Supports single channel 64-bit DDR II
    • Supports a maximum memory size of 2GB
  • Arthur Hoffmann
    what version and manufacturer are the BOIS
  • Arthur Hoffmann
    when you boot the computer, press escape when it first come on and the splash screen will go away, you should see - a ver number and the name of the bios ie: Phenoix, AMI...
HI
I TOO HAVE THE SAME BOARD ON A SAHARA LAPTOP. IT HAS TWO SLOTS. I USE 1GB IN ONE AND 2GB IN THE OTHER. HOWEVER DESPITE INTERCHANGING THE MODULES IN EITHER SLOT BOTH THE BIOS AS WELL AS THE OS RESGISTER 2GB RAM ONLY.
CPU-Z SAYS SINGLE CHANNEL RAM. BUT SHOWS 3072MB SIZE!! I.E 3GB.
MAYBE THE BOARD SUPPORTS ONLY A MAX OF 2GB RAM.
Posted on Jan 25, 2010
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
I have 5 gigs of ddr2 ram installed its shows i have 3.5 gigs is there a jumper i can change so it reads the other ram ?if i look in dxdiag it shows the full 5 gigs installed.in system information its...
http://support.hp.com/us-en/product/HP-Compaq-dc7600-Desktop-PC-series/472276/model/472278/document/c01682745/ Go to this page and make sure you have matched pairs of memory preferably all the same size and speed.
May 10, 2014 | HP Compaq dc7600 Convertible Minitower PC...
Wifi setup acced detact
i want sahara laptop wifi driver
Nov 15, 2013 | Sahara AL-096 Laptop
The sahara AL-096 DONT SEE THE USB PORTS
if it can not see the usb ports then its missing the drivers,go on to google and put in the make a model number of your laptop and let google take you to the driver download site.
Nov 07, 2013 | Sahara AL-096 Laptop
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
I need driver of wireless (wifi) of sahara bonefish al-096
Hello
check these links.
www.fixya.com/tags/sahara_laptop_bonefish_model_drivers/page-4
www.driverspush.com/al.../al-096-sahara-bonefish-drivers.html
downloadlaptopdrivers.com
http://www.dataentryjobs.us/67948.html
Feb 04, 2012 | Computers & Internet
I HAVE A WINDOWS XP PRO 32 BIT VER 5.1 2002. I JUST RECENTLY ADDED ANOTHER 2 BIT MEM STICK TO MAKE IT 4 GIS. I HAD 3 GIS TOOK THE 1 GIG OUT. SO I ADDED TO MY BOOT INI FILE /PAE. SO NOW AT STARTUP IT SHOW...
If you've got 4GB of RAM, then you'll only see something link 3200MB because some of the RAM may be shared/ dedicated for video OR most probably it is because 32 bit Windows Operating can't access 4GB Memory fully. (which 64Bit OS can access)
For further details about your CPU and Graphic processor, I suggest that you download two small free utilities
Click here to download CPUz
Click here to download GPUz
These usefull utilities will provide you all the additional details about the RAM chips installed, their bus speeds, memory available for operating system and dedicated for graphics etc.
Also, Check the memory bus speed, it should correspond to the FSB and the system should be running on 1:1 RAM to FSB Ratio (Or Higher) for optimum performance.
System performance may suffer due to RAM failure (which I have come accross a few times) Click HERE to view my tip about RAM Check. I have been working with the systems troubleshooting, upgrade etc for years n my rule is to go by the book n check every component in order to identify the issue.
Good Luck!
CreativeTECH
Apr 16, 2011 | EliteGroup Computers & Internet
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mar 11, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
My problem to my pc is i can`t install a new operating system,my old operating system is an windows xp and this is a japanese os, i want to be change the os at windows 7.i had 1g of ram 2 point something...
Hello, I´m from Argentina, then, sorry by my English. Try to install other XP, you can find in pages XP in English or Spanish, probably your problem is the language of your OS. After that, install Windows 7. If you fix the problem or not, please, write me at vcginformatica@gmail.com and tell me then will find other solution.
Feb 18, 2011 | Microsoft Windows XP Professional
How we can download the sound driver for laptop sahara model AL-096
try this possibly http://www.topshareware.com/sahara-laptop-al-096-sound-drivers/downloads/1.htm
Jun 13, 2010 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
1,105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
