Question about Garden
How to open trimmer head on MTD LT31CS Loop Handle Brush Cutter
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Where in New Zealand can I get parts for the 30cc
try looking on ebay.com
Posted on Oct 27, 2009
SOURCE: arbor stuck on gear head/bc26
I have the same problem. Any solution?
Posted on May 01, 2010
  • 7 Answers
SOURCE: is it possible to fit a brush cutter head to a
Is it a straight shaft? If so measure the inside of the blade and fit the arbor to your trimer.
Posted on Aug 17, 2010
  • 122 Answers
SOURCE: how to install brush cutter
Look at page 12 of the pdf document:
http://www.echo-usa.com/pdf/documentation/SRM210ef07_112803_1.pdf
Posted on Feb 15, 2011
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
Nov 22, 2012 | Husqvarna 123/223L Brush Cutter Kit...
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
What causes a bush cutter to vibrate
The vibration generally comes from the rotation of the motor, and the cutter head. The faster it spins the greater the vibration.
Cheers.
Jul 09, 2010 | Tanaka 40cc Bicycle Handle Straight Shaft...
The moter starts and the line wraps around the head before I can start trim.
Did you wind the string backwards? Check the head it should show which way the string shold be wound.
Jul 02, 2010 | Tanaka Commercial Grade "Inspire" Design...
Arbor stuck on gear head/bc26
Apr 20, 2010 | Ryobi Garden
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
