LCD 40 Inch Samsung HD 100Hz Has horizontal black lines every second line up to 120 mm from bottom of screen. This occurs at all times and with all sources incl.terrestial tv.It is approx 18Mths old
  • 5 more comments
  • kmh8455 Apr 18, 2009
    LA40F81BD
    I have moved the set and disconnected all exernal sources.Connected to a new single power supply and connected my digital camera to ( av1) it still shows the lines.The lines are also present on the "blue screen" prior to selecting a source
    I cannot check the line voltage but I have connected a DVD player with an HDMI output and am still getting the lines
    No I do not have any voltage stabalizing equipment or similiar with a voltage meter.
    the lines as I said previously are runing horizontally across the bottom of the screen and are stationary
    as stated earlier the "lines" are stationary, horizontal and from the bottom of the screen to 120 mm up, they are every second line of the display (in my opinion) and give it a shaded look in that area
    This is not a picture tube it is an LCD ! please someone whom has experience in LCD repair reply to this issue
    Thank you for your intelligent reply
  • 265 Answers
I had the same problem as you,
Unfortuntly the LCD had to be repaired under house insurance.
The problem was a few dead pixels in the same circuit (i.e 3 pixals on the same line will mean the whole line will go dead) This is just like a electrical circuit, and there is no way to replace the pixals with out a new LCD.
I know this has not solved the problem but it wil get you on the right track.
I recommend if you have house insurance to claim it of that, or if its under warrently.
Hope this helps
Alex
Posted on Apr 18, 2009
    Sniper:
  • 66 Answers
Dear friend this problem mainly occurs with the picture tube .
due to irregular voltage or fluctuation or high voltage the filament may have got burnt out and the capacitor is not working properly so u need may need to show up the picture tube to mechanic and he will surely tell u to get this out...
thank u.
    President:
  • 1,223 Answers
Could u pls tell me the model number of ur lcd exactly
  • 7 more comments
  • Shoaib Rais
    Shoaib Rais Apr 18, 2009
    if u take out all conn cables from it and use it with dvd player u see those lines as well
    what is the way u are connecting it thru hdmi
    and do u see these lines running in almost every mode dvd, tv, ......cable box
  • Shoaib Rais
    also tell me the power source where it is connected , is any other electrical appliance also taking power from it or not ? and do u have any computer or microwave oven or something like that running near it or on the same electric board
  • Shoaib Rais
    kindly answer me i am about to solve ur problem
  • Shoaib Rais
    Actually the power coming from board is not accurate it has dropped voltage and this is giving trouble to LCD tv bcoz it is sensitive equipment , if u are using separate power board pls if u have power meter with u kindly check the voltage supply from the electric board and tell me the current rating , where are u right no0w i mean which country check current rating accordingly if US shud get 120 volts and if somewhere else it needs to be 210-240 V please check and confirm
    One last thing do u have dvd player with hdmi out and hdmi cable with u ? if this power thing is ur problem right now u can try hdmi cable and dvd player it will not showup these lines during dvd playback i am sure
    pls replay as soon as possible i am up to solve ur problem right away
  • Shoaib Rais
    ARE THESE LINES RUNNING on screen or still in one position stable ??
  • Shoaib Rais
    do u have voltage stabilizer or any other device that is fitted with voltage meter that can show the line current
    pls tell me are these lines running from top to bottom or opposite
  • Shoaib Rais
    it is 100% power issue if these lines are running from top to bottom or vice versa u have to get a power meter and check the voltage comingfrom ur Electric Socket board in order to fully trouble shoot , these line issues are related to power problems , so pls do the needful in order to fully resolve the issue if power comes ok then only i can go forward ! pls rate me for my response if u like
  • Shoaib Rais
    ok i have found some info for u direct from SAMSUNG
    The
    line you see rolling through your picture (usually starting at the bottom and
    rolling up to the top and then repeating), can have one or more causes.
    To
    determine the cause of the rolling line, follow these steps:
    1. Check
      for the rolling line on all the sources you use (cable, component, HDMI,
      etc.).
    2. If
      the rolling line appears on all sources, your TV may not be grounded properly.
      The grounding problem can be caused by the TV or the outlet you’ve plugged
      the TV into. Check the grounding of the outlet. If the outlet appears properly
      grounded, then your TV is not grounded properly and needs service. Please
      click the Create Online Service Request button below. If the rolling line
      does not appear on all sources, continue to Step 2.
      Important:
      Using a three prong to two prong adapter on the television’s plug removes
      the grounding on the TV and can cause rolling lines.
    1. If
      the rolling line only appears on one source, it may be caused by electromagnetic
      interference, low signal strength, or faulty wiring. To identify the cause
      of the rolling line, read the appropriate troubleshooting recommendations
      below.
    pls tell em the results it is power issue
  • Shoaib Rais
    have u checked this grounding thing i got from Samsung
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Why does my samsung ln40d630 lcd tv have a horizontal line across the screen about mid height? The line is present using all the different sources.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 13, 2014 | Samsung Ln40d630 40-inch 1080p 120 Hz Lcd...
Black vertical line of approx 1 mm from top to bottom of the screen at 80mm to the right of Samsung LCD TV LA40C630K1MXXs
I have hate to say it, but you need to replace your panel. Would be more cost effective to replace your set.
May 20, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I hv 40 inch samsung lcd model 40456c2d its with dv3 hd ready srs tru surround xt can u pls give the operational manual and i hv colored horizontal thin lines on the left hand side screen about 6 inches...
Most people would have a hard time finding that manual because it's not a 40456 it's a 40A456
Your manual is located here:
http://downloadcenter.samsung.com/content/UM/200803/20080322095034640_BN68-01424A-00L08-0305.pdf
Have a wonderful day!
Feb 22, 2011 | Televison & Video
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
CircuitCity
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
