Question about Dryers
My maytag electric dryer is not getting hot.
My magtag electric dryer: Model LDE9304ACE is not getting hot. The plug in cord burned from the base of the plug where the metal prongs meet the base of the plug. I replaced the plug in cord and now m dryer works, but it is not getting hot. It is also no moving through thr cycle whe the knob is turned. The knob doesnt move through any cycle, even if i change which cycle it is on.
  • 659 Answers
It sounds like the element shorted out and caused more damage to the unit. Remove and check the heating elment, thermal fuse (located near element), and timer. The timer will be hard to test if you don't have a meter. I would suggest that you check the element first. This is probably your main problem.
Posted on Apr 18, 2009
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
WHAT ARE THE COLOR WIRE SEQUENCE TO THE TERMINAL BLOCK ON MAGTAG DRYER. NOT THE CORD SIDE BUT FROM THE DRYER. IE BLUE WIRE GOES WERE/
Blue is one of the HOT WIRES it goes on one of the outside terminals
Typically black is on the left
white in the center
blue on the right side
parden my crudely made photoshop usage
i spend a long time and get it the way i want
i made this on in 2 minutes
Aug 22, 2011 | Maytag Dryers
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replaced the electrical cord on maytag atlantis dryer < a year ago, but now it seems the hot connection is burning up.
BOTH HOT "L1" and "L2" connections or just one of them is burning up? if just one you could have a partially shorted heating element drawing excessive current
Sep 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My magtag dryer mde9520 won't heat. How do I tell
You need a multimeter to test the voltage and continuity
Jun 30, 2009 | Maytag Dryers
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag dryer
Replace the cord first. You won't be able to tell for sure unless it's replaced. Dryers pull so many amps and the dryer cord becomes hot while running it. The heat causes them to break down over time.
Apr 10, 2009 | Maytag PYE2300AY Electric Dryer
Magtag Electric Dryer
Replace the thermal fuse and high limit switch located at the heating element.They come as a set.
Correct the blockage in the dryer connecting vent at the rear exhaust port.
Mar 09, 2009 | Maytag PYE2300AY Electric Dryer
I need instructions to install belt on my clothes dryer Model no.lde9304ace
HI,
Please CLIcK HERE all the steps are given including pics to install a belt on your dryer.
Jul 23, 2008 | Maytag Dryers
Maytag atlantis
Usually you will encounter a situation where a wire will burn off and in so doing, it may trip a breaker,(turn it off then back on to be certain), or if fused, it may blow a 30 amp glass fuse or 30 amp cartridge fuse. Replace both tho eliminate any doubt. If all checks ok, disconnect the dryer from the power source and go internal to find the problem. Below is a popular link to provide you with more assistance, should you need it.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Jun 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
234 people viewed this question
Top Dryers Experts
