FixYa.com
Tags:
Monitors
Generic problem for all Monitors
Proview PL716s computer monitor (by 7 users)
posted by Trofeo on Sep 17, 2007
I have a Proview PL716s monitor and it now powers up and displays a proper image for about a second and then goes to blank. The power LED remains a solid green. I have confirmed that the computer is putting a steady signal out. Any thoughts?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by amdada, posted on Jun 06, 2008
no power led on
Comment by Irishgal, posted on Dec 30, 2007
I just bought a PROVIEW PL716S LCD MONITOR off of ebay ( seller said it worked perfect) And I plugged it all in and Led Green light for power is on.No error messages. But It shows desktop for 3-12 seconds, then flickers ever so slightly and then goes pitch black. I tried this on my laptop and home pc with same results. The ebay seller wont give me an exchange or refund. Also if I unplug the Video cable I will get the " no signal" sign in colour.
please email me if u know what may be wrong. Im so disheartened, Gift for my kid for xmas. clarissahiggins@hotmail.com
Comment by Guest, posted on Dec 20, 2007
Same Problem with an AMW 17 inch lcd. on power up the screen image lasts about two seconds then switches off no warning not sure what to do with the monitor.
Comment by Guest, posted on Dec 07, 2007
ZADFH
Comment by Guest, posted on Nov 26, 2007
I have pluged and unpluged everything. I have it installed on a circut breaker. I have tried F8 and F5, but none of these work. I have tried to replace the plug from the monitor to the computer, as I am getting a "no signal" on my monitor. I have not been able to find a replacement cord to see if that is the problem. I purchased it from Circut City 2 years ago and they cannot provide me with any information where to purchase a cord. So at this point I cannot get anything off my harddrive.
Best Solution
posted on Sep 18, 2007
FixYa! (100)
craig13
Rank:Guru Guru
Rating: 86%, 89 votes
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 21, 2007
Helpful (85)
ajith
Rank:Guide Guide
Rating: 85%, 27 votes
the problems usually seen a short in mosfet irf 630 abad lineoutput transformer and abad deflection coil
Solution #3
posted on Apr 08, 2008
Not Rated (0)
delorean831
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
I opend up the monitor and found that some of the capacitors on the power circuit are bulging. I'm pretty sure that is the problem. I just ordered substitute capacitors and will replace the broken ones with them when they arrive. specs for equivalent capacitor: 470uF 25V 105C
Solution #4
posted on Feb 27, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I have no solution for this problem but I am looking for a instruction manual for a Proview Pro 720 2000. wrpwjp@entwe.net
This Problem Also Relates To: HP 2025 (Carbon, Silver) 20.1 in. Flat Panel LCD Monitor HP 91 (White) 19" CRT Monitor Philips 170B5CB (Black) 17" LCD Monitor Philips 230W5VS (Silver) 23" LCD Monitor Acer AcerView 78ie (White) 17 in.CRT Conventional Monitor Acer AL1916B (Black) 19" LCD Monitor AOpen F70PS (Black) 17 in. Flat Panel LCD Monitor
Can you Help with these Monitors problems?
Toshiba P000232050/F 13.3" LCD Monitor
interference lines and patterns...
I have noticed what seems like... Answer This...
Samsung SyncMaster 204B 20.1" LCD Monitor
monitor
we have had this monitor for a... Answer This...
Monitors
Faulty backlights
What can I do to repair my... Answer This...
ViewSonic VX924 (Silver, Black) 19" LCD...
ViewSonic VP2920b
Can I turn my monitor from... Answer This...
Tatung - LD23HL Monitor
TATUNG LD23HL
trying to find a repair center... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by JN_Jr, posted on Nov 02, 2007
Screen went blank and pressing power button makes it life - displays proper image - for split second only. At first after pressing power button several times it would start working - that was few weeks ago, now nothing helps. I connected different monitor and image display is perfect. Reading two solutions to exact problem didn’t help since there is too much lingo that I do not understand and do not know what the next step is.
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
