Question about Mitel 5220 IP Phone
Mitel 5020 Dual IP phone, second SIP doesn't register, help
Hi, I set up the two users in this phone, two SIPs. But Now I get only one registering. Help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Do you have licenses for them.
Posted on May 14, 2009
I am trying to register my Mitel 5201 IP phone to our mitel system but it is not working. The message indicator light does want to flash anymore, nothing happens when i connect it. Please help!!!
the 5201 set must be registered manually in the phone system. Log into the system. Change the extension. Type the MAC address of the phone in the proper field in the form. The MAC address is located on the bottom of the phone.
Sep 14, 2010 | Mitel 5201 IP Phone
How do I cahnge the ip address on the linksys spa941 when it failed to registered: it is not picking up ip address from the switch.it was working before change the switch
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
Jun 09, 2010 | Linksys SPA941 IP Phone
I have Netgear N router and having problems trying to establish phone connection with my Mitel 5312 ip phone. I have fowarded all the ports, disabled router firewall powercycle everthing a thousand times...
The phone is intended to be connected to a Mitel PBX telephone system. If you're using the phone at home, you must set the phone in Teleworker mode and use the IP address of the teleworker server. This will allow your phone to tunnel into the phone system.
OR the phone must be set up in SIP mode. Press and hold the 6 key while booting the phone. You will also need to set it up and tell it where the SIP server is located (IP addresses).
If you don't have this information, you should contact your vendor or system admin for further assistance.
If you are trying to use the phone without the above servers, I have bad news - it won't work.
Apr 07, 2010 | NetGear MR314 802.11b
My handy tone-486 box keeps flashing red every 3 seconds and I have no dial tone. My internet works and I have power and a working phone line to the box. Help.
Lifted this straight from the manual:
Button flashes every 4 seconds
(if SIP server is configured)
HT–486 fails to register
So basicly, that means your HandyTone 486 ATA fails to register with the SIP-server. That means you either have not recieved your IP-tele yet, or that your ISP have failed to register you.
Mar 04, 2010 | Grandstream HandyTone 486 ATA (HTATA486)
I want to change the time on the face of my 5020 mitel phone. I have a user manual but it does not address this issue. Please help! It's an hour and 10 minutes ahead and it's hard to work thinking it's 5pm...
Login to phone system or you can setup the time thru the console or a sub attendent phone. If the class of service has that option. It is a little different for the different Mitel phone systems.
Dec 21, 2009 | Mitel 5020
Mitel 5020 holding
What is the problem with this? Are you referring to the Music on Hold? If so, what do you have for MOH? What phone system do you have? The 3300 ICP can have the music embedded into the programming. All other Mitel systems have to use an external source.
You should contact your vendor for assistance.
If you're referring to the hold time, you should contact your vendor to change it.
Dec 03, 2009 | Mitel 5020
I want to change the time on my 5020 ip phone
Hello!
The manual for your phone can be found at the Mitel website, here:
http://edocs.mitel.com/UG/EN/31_5020_NA_R4.0.pdf
Oct 26, 2009 | Mitel 5020
I need to know how to find out what the pin is for a Mitel 5212 IP Phone I have but has never been used.
Hi...maybe that pin is your password when registering your phone after the extension#...e.g *91 + extension# + password(pin)
Oct 22, 2009 | Mitel 5212 IP Phone
Mitel 5220 ip phone locked out
Make sure that it is a Dual Mode 5220. If it is you can use it as a SIP extension. It wiill say it on the back of the Mitel phone next to the 5220.
If it is a dual mode phone you can purchase a sip trunk from a provider and then would be able to use the phone.
When you boot up the phone hold the blue super key while the phone boots, hit the no softkey till you get to phone mode. Hit yes it will allow you to change the phone from minet to sip. This should get you started in the right direction.
Jul 30, 2009 | Mitel 5220 IP Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
Mitel 5220 IP Phone Logo
269 people viewed this question
Top Mitel Computers & Internet Experts
rey francis basa
rey francis basa
danoyachtcap
danoyachtcap
Jay Plesset
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
