Question about Technics SL-1210 Turntable
Technics sl-1210mk2 which fuse (the clear or the stripey) is placed horizontically, and which one is placed vertically inside the deck? i forgot to notice it when i removed them to check which one was blown... thanks!
  • hhaugland Apr 18, 2009
    yes there is! now i get it! thanks for your help!
  • jason May 11, 2010
    is there an amp rating on the board for each fuse ?
    and doesn't the fuses have the amp rating engraved on the end off the fuse ?
  • 905 Answers
This should help determine which one goes where but they may be the same , so it wouldn't matter if they have the same voltaage and amp. rating
Posted on Apr 18, 2009
  • jason Apr 18, 2009
    your welcome, and thanks for using fixya !
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Fried my electrical supply...
hi aris tomas...1st check the fuse inside the turntable..then if its ok go to the main board  ..check the zener diode (D3)  and the transistor Q3 and Q2...the fidbk me wat hapen , if possible if you can chance it replace it..u
Jan 31, 2009 | Panasonic Technics SL-1210MK2 Turntable
Internal fuse
The Solution:
1. Firstly unplug the decks!!!
2. Remove the slipmatts and platter
3. Unscrew the circular plastic cover (Note: 5 screws holding it down)
4. Upon removing this circular plastic cover you will see a clear piece of plastic covering a circuit board, open it up. Now you will see a two fuses one clear and one stripey. 5. Remove the fuses (Gently poke it out with a pen/screwdriver or whatever) and examine it and see if either or both have infact blown.
6. Bring the suspect fuse/s to any electric/hardware/music type store (or search the net) and try to get a replacment but make sure its the same as the fuse you removed!!!. A T250 mA fuse(clear) an a T1A Fuse (stripey) are stated in the Technics user manual.
7. Now get the new fuse and gently snap it back in to the silver holders.
8. Replace the clear plastic circuit board cover.
9. Screw back the the circular plastic cover (Note: 5 screws holding it down)
10. Replace the Platter and slipmats
Sep 04, 2008 | Technics SL-1210 Turntable
Deck speed up to uncredible speed and wont stop
You both have issues with your drive circuits. There is no easy fix for this. You will have to take it to a repair center to have them serviced.
There are 4 main Integrated Circuits that control the speed/drive and any one or all may have gone bad. We are seeing this alot with these units now.
Wish I could be of more help.
- OPTiC
The 1200s Expert
www.1200s.com
www.repairnyc.com
DJ Pro Audio
Aug 23, 2008 | Technics SL-1210 Turntable
Technics 1210mk2 turntable
Hi Dezzy
Go look here There is heaps of information on your deck. There is not alot to service, just some adjustments. If you have any problems with the T/T, got back to me here. So spruce em up and go drop some nasty tunz:)
regards
Graeme
Mar 07, 2008 | Audio Players & Recorders
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
167 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
